Highlighted
Beginner
BLF/Speed Dial is not working
Here is the steps I followed
  • Enable the BLF for Call Lists (enterprise parameter).
  • Allow subscriptions for presence cluster wide (service parameter)
  • Configure phone button templates using speed dial BLF.
  • Assign templates to phones.
  • Add BLF speed dials to phones.
  • All the phones are in PT- Internal and CSS-HQ
  • Reset CCM service and phones
CUCM version 7.1.3-10000-11
IP Phone- 7961 and also tried on 7945 same results
BLF does not work but speed dial is working! what am I missing here
Thanks for your help in advance
1 ACCEPTED SOLUTION
Highlighted
Re: BLF/Speed Dial is not working
Check the configuration of the Device...
Go to "Protocol Specific Information" and under SUBSCRIBE Calling Search Space you need set a valid CSS to reach "Internal" number
Hope this help!
Alberto
12 REPLIES 12
Highlighted
Beginner
have you checked that that Subscribe Calling Search Space on the phone or user is set and has the required access?
Paul
Highlighted
Beginner
Thanks Paul
I did try putting the CSS on the user (I have css on the phone which has access to all partitions)  which I didnot configure before and reset the phones but no change in BLF! still BLF is not woking!!
Highlighted
Hope this help!
Alberto
Highlighted
Beginner
Hi.. It worked from me as well. But for me since I had extension mobility, I had to select the BLF presence Group under UserManagemet ---> end user. Also I had to select an appropriate value for SUBSCRIBE Calling Search Space in the End user page.
Bejoy Thomas
Highlighted
Beginner
this corrected my issue on
this corrected my issue on the 8851 models as well - forgot about this drop down option. Thanks for posting it.
Highlighted
Beginner
This worked for me.  Thanks!
Highlighted
Beginner
This was the missing part to making the BLF light come on when that person is on the phone for me.  I wouldn't have made the connection with SUBSCRIBE Calling Search Space for the BLF.
Highlighted
Beginner
That's helpful to me. But I had to make valid css "Monitoring Calling Search Space" in the line configuration.
thank you,
Burak
Highlighted
Beginner
Thank you - Bang on fixed my problem :)
Highlighted
Beginner
Bingo
Its working
Appreciated your help
Highlighted
Beginner
Bingo from me, too!!!
ya the man!!
Highlighted
Beginner
That worked, thank you.
