BLF SpeedDials NO Find Button
Ahmed Awida
Hi Guy,please take a look to the picture attached .
I can't find the Find button to be able to search for directory numbers,instead of uing the drop down list.
I have this button in different cucm servers other than this one i am working with now.
11 Replies 11
Ayodeji Okanlawon
Ahmed,
That is strange. What version of CUCM is this?
Have you tired using another browser? eg  ie or chrome?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
To be honest, I've never seen a search field on that page, in no version I've visited.
Simply typing in the directory number field the number you are searching, it displays if exists.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Carlo, there is a "Find" that allows you to search for directory numbers to add for your BLF speed dials
Aok.
This is an 8.6 of one of my customers.
Where is the find you are talking about?
Carlo,
Here is mine on CUCM 8.6.
I think it depends on the amount of DN that you have. If your DN exceed the amount that can be seen in the drop down menu, then the find button appears
Yes.
This could be the possible cause. +5P Aok
THX
Carlo
Hi Carlo.
Yes there should be find button.
Hi aokanlawon
Tried but all browsers does not show .CUCM 9.1.I used it for other customers and i have find there.
Ahmed, did you read my post above
It depends on how many Extensions you have.
May be you are right.
Hello Community, I notice the same issue at the enduser configuration.
Please see this thread
No " Find " Button in CUCM End User Configuration
https://supportforums.cisco.com/message/4136032
I can´t find anything in srnd etc.... regarding the limit.
For doublecheck I would increase the count of Deviceprofiles.
From which limit the "find button appears"?
HTH, please rate all useful posts!
HTH, please rate all useful posts and right answers.
