ā01-18-2018 12:17 PM - edited ā03-17-2019 11:59 AM
I have a DID Range 6000 to 6999. I need to block any calls coming to 6751 from Gateway.
6751 should be accessed internally within Office. No External Calls should come to 6751. Please help to achieve this.
ā01-18-2018 12:20 PM
Several ways to accomplish this. One way is to put this DN in a partition that is accessible by the CSS assigned to internal phones but not by the CSS assigned to the gateway.
Brandon
ā01-18-2018 12:31 PM
Thank you..!! Is there a Way to achieve this by making any changes in gateway ..?
ā01-18-2018 12:34 PM
Are you using an H.323/SIP gateway? You could use a translation rule.
Brandon
ā01-18-2018 12:39 PM
ā01-18-2018 12:42 PM
Is carrier sending 4 digits or sending more and the call is being translated to 6751 in CUCM. At the gateway you will need to match the incoming digits. Run "debug voip dialpeer", make the inbound call and you will see the called number.
Brandon
ā01-18-2018 12:46 PM
ā01-18-2018 01:17 PM
What type of gateway? Is the call hitting the dial peer where you have the translation applied?
ā01-18-2018 12:32 PM
+5 to Brandon for using fewer words! :)
Because, as ancient Spartans said, brevity is the source of wit!
One way to do this is assign the 6751 DN in a new partition, and that partition would only be included in the IP phones CSS. It should not be included in the gateway's (incoming) Calling Search Space.
ā03-05-2018 10:44 PM
sh run | s voice-port
# go to config mode of the VGW
# config t
# voice-port 0/0/1:15
translation-profile incoming <translation profile name>
