04-17-2018 07:48 AM - edited 03-17-2019 12:38 PM
Hi Guys,
I have done this before but it has been a while since then... Anyways, there are a few marketing numbers that our AR dept wants me to block, i don't want to do it in CUCM. I think it is more effective to drop the call as soon as it gets to the CUBE.
Here is what i tested and it didn't work... Perhaps another set of eyes can shed some light.
Let's say i want to block all calls coming from PSTN number : 76074094XX. Want to block the call on CID for number 76074094XX aka any call from that # should be blocked.
1. voice-translation rule 760
rule 1 reject /76074094XX/
2. voice translation-profile Block-incoming
translate calling 760
3. Then apply the translation-profile to the Incoming Dial-peer from SIP provider
dial-peer voice 760 voip
description Incoming FROM SIP-TRUNK
translation-profile incoming IN-ITPS-CALL
call-block translation-profile incoming Block-incoming
call-block disconnect-cause incoming call-reject
session protocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
04-17-2018 08:33 AM
Change rule 1 reject /76074094XX/ to rule 1 reject /76074094../
04-17-2018 08:43 AM
Hi Chris,
Thanks for the reply... XX has replaced the last two digit, just for privacy concerns.
But i my config i have added the full ten digits in the rule ans still NADA. What i am thing is the direction of that i apply it in voice traslation-profile. It's calling i wonder shall i change it to translate called 760.
And thanks again for the input.
04-17-2018 11:11 AM
Can you provide "debug ccsip messages" and "debug voice translation"?
04-17-2018 01:29 PM
Hi Chris,
Thanks for the help... But the issue has been fixed.
It seems the dial with coming number as a (.) was to general. I've added another DP with the exact number on which i want to block and it works ax expected.
Cheers
04-17-2018 01:33 PM
Excellent. Thanks for the update.
