08-29-2016 07:18 AM - edited 03-17-2019 07:57 AM
I have found many documents demostrating how to do this:
https://supportforums.cisco.com/discussion/11283866/blocking-calls-cucm
https://supportforums.cisco.com/document/77241/technotes-how-block-incoming-calls-cucm-8x-based-ani-mgcp-gateway
https://supportforums.cisco.com/discussion/11871421/blocking-incoming-calls
With the most informative and popular being
https://supportforums.cisco.com/document/71966/blocking-calls-based-calling-party-id
Here are my concerns.
It appears thet if you block ANI in CUCM (8.0 and above) it has to analyze every single call thenblocks it if it finds a match. Howvwer, if you look in the replies, many people are having a problem with Unknown callers. I cannot implement this in Call Manager if I am going to experience any call blocks other than the ANI I have specified.
Can someone advise if they are successfully blocking the calling party number in a production environment?
Here is a link to a non-MGCP gatweway block but this is not relevant as I have MGCP gateways in my production environment
08-29-2016 10:07 AM
The 'anonymous' or 'unknown' call issue is when you use SIP Gateway.
With MGCP gateway, you will not face any such issues. You may implement this solution.
08-29-2016 10:09 AM
I have not set this up in a production environment as I dislike MGCP but have tested it successfully in a lab using the blog published by William Bell at the link below:
http://www.netcraftsmen.com/cisco-cucm-blocking-calls-by-calling-party-number-id/
hth
