I followed the below guide which worked out great on my PRI circuits.
https://supportforums.cisco.com/docs/DOC-18367
Does anyone know for incoming calls on a T1 CAS if I would define the ingress Filter CSS on the device information calling search space? On the PRI it was defined on Call Routing Information - Inbound Calls.
Thanks!
J
There should be no functional difference between the two. The only thing I'm thinking is if there would be any restriction with the digit by digit dialing functionality of the T1 CAS although we dont have a documented restriction that I remember.
