07-20-2016 12:50 AM - edited 03-17-2019 07:35 AM
I am using same number for two phones. For first number it will be primary line and for the second phone it will be secondary line only to make international calls.
I want to configure in such a way that whenever incoming call comes on that number only first phone should ring but not the second one.
I am using CME.
Any one pls guide how can i achieve above.
Faizan.
Solved! Go to Solution.
07-20-2016 06:07 AM
Not sure I follow, are you saying that the caller ID needs to be from this number in order for the call to succeed due to carrier ANI validation? If so, you could write a translation rule to change the calling number to the allowed number from the new extension only and apply to either the international dial peer or the ephone-dn.
07-20-2016 06:26 AM
Voice translation-rule 1
rule 1 /22234567/ /22212345/
voice translation-profile xlateDN
translate calling 1
ephone-dn 1 dual-line
translation-profile incoming xlateDN
07-20-2016 05:59 AM
So, why do you want the same number on both phones? If it only needs to ring on one and the second should have specific COR why not simply assign 2 different numbers?
07-20-2016 06:03 AM
We have international access on only one number, so we are planning to assign the same number to two phones to make international calls.
07-20-2016 06:07 AM
07-20-2016 06:20 AM
Yes, exactly.. international call will succeed only when the caller id will be this number.
Can i write like below... (22234567 is the calling number and 22212345 is the number to translate)
number 567
translate calling 1 (translation tag number)
Please suggest.
07-20-2016 06:26 AM
translate calling 1
07-21-2016 12:53 AM
Hello Chris,
Everything is perfect with the above config.
Am just testing in my lab to translate the number only when the international call is dialed but not on local dial.
I tried to apply type and plan in translation rules, but hard luck...none succeed.
Can you suggest how to achieve it.
07-21-2016 05:32 AM
Instead of applying the translation profile at the ephone-dn level apply it in outgoing direction to the international dial-peer.
07-21-2016 05:53 AM
When i dial international number starting with 00, number is getting translated and going out with international dial-peer, and getting rejected ( getting disconnect cause code 21 while debugging ).
07-21-2016 06:38 AM
Is it only happening when you apply the translation?
if so, can you provide output of "debug Isdn q931" if this is PRI or "debug ccsip messages" if sip trunk for a working and not working call.
07-24-2016 01:16 AM
Yes, call getting dropped only when translation is applied.
Attached are "debug voice ccapi inout" output for both working as well as non working calls and running config.
Calling number= 988 (877 is the translated number)
Called number = 00918019843455
Please suggest.
07-24-2016 02:44 AM
Its working now.
I wrote translation rule wrongly.
Thanks for your support.
