12-28-2010 04:40 AM - edited 03-16-2019 02:36 AM
Can I block extensions (11xx) calling extensions (22xx) on one CME, is that possible?
regards
Solved! Go to Solution.
01-04-2011 04:07 AM
I tried the following config in my lab and it works perfectly fine. Try this:
voice translation-rule 12
rule 2 /^22../ //
voice translation-profile block
translate called 12
ephone-dn 2 dual-line
number 1111
translation-profile incoming block
Now extension 1111 will not be able to dial nos. in range 22XX
Do the similar config for 22XX phones.
Nitesh
PS: Pl rate helpful posts
12-28-2010 04:53 AM
Yes, use COR, or blocking pattern in ephone-template, or voice translation-rule.
12-28-2010 12:48 PM
You can use COR lists to achieve your end result. Refer the following doc for more help
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
A more easier method would be to use translation profiles as shown below:-
1) Create a voice translation rule to block the called numbers namely 22XX
rule 1 reject /^22../
2) Create a voice translation profile and add this rule there
voice translation-profile profile1
translate called 1
3) Apply this profile to the outbound dial-peer to block the calls
dial-peer voice 2200 pots
destination pattern 22..
translation-profile outgoing profile1
For further help pl refer the following doc on translation rules
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Make the relevant changes and check the result.
Nitesh Sinha
P.S:- Please rate helpful posts.
12-31-2010 09:37 PM
thank you for reply.
if I have all extensions in range (1100-1199) and (2200-2299) and participate one operator, are they blocked from calling each other and participate in one operator?
01-01-2011 01:35 AM
Can you make your question clearer? I think you have some kind of operator in one of the ranges and want the users to be able to dial the operator only and not vice versa. Is it true? Pl describe your problem clearly.
Nitesh Sinha
01-01-2011 03:44 AM
both ranges have same one operator, both ranges they cannot reach each other directly each one working separately, but they can reach each other through operator.
let`s say the operator has extension 3333 and (A users) have extensions between ranges (1100-1199) and (B users) have extensions between ranges (2200-2299), the A users cannot reach B users directly, if A users need to reach to B users they have to call the operator then the operator will transfer the calls to any extensions they need.
I hope this will be helpful.
regards.
01-01-2011 10:49 AM
Hi kingofshadows86,
You can do the following:-
1) When users in range 1100-1199 dial nos. in range 2200-2299, transform the called nos. to a number which is not being used in your dial-plan, say 5555 so that this transformed number will not ring any phone.
2) Similarly when users in range 2200-2299 dial nos. in range 1100-1199, transform these called nos. to a number which is not being used in your dial-plan, say 5555 again, so that this transformed no. will not ring any phone.
3) When users in both the range dial the operator, don't transform the called number. Let it go through and ring the operator's phone so that he can transfer the number.
Nitesh
PS: Pl rate helpful posts.
01-03-2011 08:20 AM
Could you be more clearer above! How exactly?
I have tried all this below and no one is work, still the phone is ring
rule 1 reject /2222/
voice translation-profile REJECT
translate calling 1
Then applied on the ephone
ephone-dn 1 dual-line
number 1111
translate calling 1
translation-profile incoming REJECT
and the other tried is
dial-peer cor list internalcalls
member internal
dial-peer voice 1 pots
corlist incoming internalcalls
call-block disconnect-cause incoming call-reject
destination-pattern 11..
number 2222
any suggestion please
regards
01-03-2011 12:31 PM
Try this.
rule 1 reject /22../
Then apply it on the ephone
number 1111
translate called 1
Now phone 1111 should not be able to dial any phones in range 22XX.
Do the similar config for phones in range 22XX also.
Do post you results.
Nitesh
01-03-2011 09:48 PM
Thank you for reply.
I tried it, but nothing the Ext.1111 still can dial 22xx.
another suggestion.
regards
01-04-2011 04:07 AM
rule 2 /^22../ //
translate called 12
number 1111
Nitesh
