04-13-2011 07:22 AM - edited 03-16-2019 04:29 AM
is it possible to create a access list global and assign it to more users in remote destination? At the moment i have to create for every remote destination user a acl with owner of the user. If i create a acl with no owner i have the rule but in remote destination i can`t assign it to the user? How can i assign this acl to more users?
I want to create a acl who blocks call forward to mobile phone if the user is in a specific hunt list only the directory number should ring. That`s the point....
system: CUCM 8.5
any suggestions?
thanks and regards
jason
04-13-2011 08:05 AM
Exactly what do you mean by ACL here and what do you want to do.
In CUCM the only way on which you allow or restrict calls is based on having a route pattern/translation pattern that allow or block the call and then assigning them to the users via partitions and CSSs
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-13-2011 08:11 AM
Hmmm but i mean this option in "Remote Destination"
"When receiving a call during the above ring schedule: -> Do not ring this destination if caller is in
This worked if i create a ACL especially for a user. But the point is i have to configure than many ACLs fr every user which is in this hunt list (line group)....
Do you know what i mean ?
