07-11-2011 12:51 PM - edited 03-16-2019 05:54 AM
Hello Dears,
I'm trying to block calls to PSTN Network, especially international calls for specific extensions (IP Phones).
I'm not able to do it through the after-hours block calls, because of the destination-pattern I'm using under the dial-peer voice pots
I'm using the following Pattern ( destination-pattern [9] ), when I do press 9 i'm redirected to the PSTN line but no restrictions on calls.
I'm using the following config under the telephony-service:
after-hours block pattern 1 900............
after-hours block pattern 2 90.........
after-hours block pattern 2 90T
but nothing happened.
any idea please
thanks
Ibrahim
07-12-2011 11:54 AM
Hello Ibrahim,
here is a small configuration example for a realy basic german dialplan:
1. Create / define your COR List Members
dial-peer cor custom
name Emergency
name Local
name National
name International
name Mobil
name Service
2. Create the COR Lists for your outgoing dial-peers
dial-peer cor list CallNotruf
member Notruf
dial-peer cor list CallLocal
member Local
dial-peer cor list CallNational
member National
dial-peer cor list CallInternational
member International
dial-peer cor list CallService
member Service
dial-peer cor list CallMobil
member Mobil
3. Assign the created COR-Lists to the dial-peers
dial-peer voice 1 pots
description ***Notruf***
destination-pattern 011[02]$
corlist outgoing CallEmergency
prefix 11
port 0/0/0
dial-peer voice 2 pots
description ***Local Calls 1st***
destination-pattern 01[2-9]T
corlist outgoing CallLocal
prefix 1
port 0/0/0
dial-peer voice 3 pots
description ***Local Calls 2nd***
destination-pattern 0[2-9]T
port 0/0/0
dial-peer voice 4 pots
description ***National - only an example !!!!***
destination-pattern 00[2-8]T
corlist outgoing CallNational
prefix 0
port 0/0/0
dial-peer voice 5 pots
description ***International***
destination-pattern 000[1-9]T
corlist outgoing CallInternational
prefix 00
port 0/0/0
dial-peer voice 6 pots
description ***Mobiltelefon***
destination-pattern 001[5-7]T
corlist outgoing CallMobil
prefix 01
port 0/0/0
dial-peer voice 7 pots
destination-pattern 0[0]900T
corlist outgoing CallService
port 0/0/0
4. Create COR Lists for the client's / phone's
dial-peer cor list Manager
member Emergency
member Local
member National
member Service
dial-peer cor list Employee
member Emergency
member Local
member National
dial-peer cor list Visitor
member Emergency
dial-peer cor list Public
5. Assign the COR to the ephone's
ephone-dn 1
corlist incoming Manager
ephone-dn 2
corlist incoming Employee
ephone-dn 3
corlist incoming Visitor
ephone-dn 4
corlist incoming Public
Kind regards,
Marcel Ammann
P.S.: Please rate helpful posts
07-12-2011 12:46 PM
Hi Marcel,
I Appreciate your help Dear,
I'm gonaa do all tests tomorrow & let you know the results.
Thanks in Advance
Ibrahim
