03-15-2017 07:53 AM - edited 03-17-2019 09:49 AM
Hello all,
I tried to block block specific incoming call number on FXO (H323 voice gateway) without luck.
I have H323 VGW with 8 FXO ports at one branch office, CUCM 8.6. All FXO ports are configured as one trunk-group.
I tested with translation-rule, translation profile and incoming dial-peers configuration below. It looks the incoming calls dial-peer is 0, which doesn't exist on my H323 VGW configuration.
Question:
Is it correct direction to block the calls as per my configuration below?
I am not sure if my incoming dial-peer configuration is correct or not. If not, any advice?
Thanks in advance!
voice translation-rule 11000
rule 1 reject /**********/ (I enter my phone number)
voice translation-profile call_block
translate calling 11000
dial-peer voice 50 pots
description ** incoming dial peer **
trunk-group ALL_FXO 64
incoming called-number .
call-block translation-profile incoming call_block
no sip-register
Best regards,
Master001
03-15-2017 08:25 AM
Configuration seems correct.
Check what Provider is sending the Caller Id and if it is matching the correct dial-peers.
When call is active issue commands and paste the output here
show voice call status
show call active voice
Haris
03-27-2017 09:31 AM
Please see my incoming call dial peer configuration and "show voice call status" capture below.
Looks the incoming calls do NOT hit the the incoming call dial peer, as I have tested and found this previously. As a result, the call blocking doesn't work, as I block the call via the incoming call dial peer.
Any idea ?? Your help is appreciated.
trunkgroup ALL_FXO
no sip-register
VGW#show voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x1A 1220 0x2CE21BB4 0/0/0 0/1:1 49999 g711ulaw 0/84
1 active calls found
(I called the branch office main office, the call was forwarded to Unity connection branch greeting (49999). So you will see the called # is 49999.)
