562
gridnutter
Beginner
Blocking External Caller ID for Specific DN's
Call Manager 6 platform.
How can I block the Caller ID for 2 specific directory numbers when they dial any external number?
2 REPLIES 2
gridnutter
Beginner
I tried creating a new 9.@ route pattern and set the Caller ID to restrict. I then created a new CSS and Partition for the 2 phones.
For some reason it seems that this route pattern is being used globally, and is restricting Caller ID for all phones.
Jaime Valencia
Hall of Fame Cisco Employee
The process is very simple, you mentioned you created a new CSS and PT for phones?? because that doesn't make sense if you want to block the CLID from those 2 phones in the RP for PSTN outgoing calls.
You need to create a new CSS and PT FOR THE ROUTE PATTERN.
Then make sure only those 2 phones have that partition in their CSS.
In the RP use the calling party transformations to block sending their DN.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Create
Recognize Your Peers
Content for Community-Ad
