01-29-2015 08:37 AM - edited 03-17-2019 01:46 AM
I understand there have been lots of posts like this but unfortunately my config is not working even after following those. maybe it is because of call center involved? I am calling the number directly though and we are only sending mainline number to call center so that may not play a role here but im not sure.
Below are my config and debugs and attached is my config (deleted some info not related). Please point out what im missing :(
I configured new voice translation
voice translation-rule 2
rule 1 reject /09399312213/
Created translation Profile
voice translation-profile call_block
translate calling 2
Apply to Incoming Dial-peer
dial-peer voice 1005 voip
description VoIP Dial-Peer to Subscriber
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
destination-pattern 23..$
session target ipv4:10.203.2.116
incoming called-number .
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
MAN-VOIP-02#sh run | s dial-peer voice 1006 voip
description VoIP Dial-Peer to Publisher
preference 1
session target ipv4:10.203.2.115
voice-class codec 1
voice-class h323 1
no vad
DEBUG
MAN-VOIP-02#
Jan 29 15:12:01.187: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x011F
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98383
Exclusive, Channel 3
Calling Party Number i = 0x2181, '09399312213'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '2301'
Plan:ISDN, Type:Subscriber(local)
High Layer Compat i = 0x9181
Sending Complete
Jan 29 15:12:01.187: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x811F callID = 0x00B4 switch = primary-net5 interface = User
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=09399312213, Called Number=2301, Voice-Interface=0x14152D7C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Calling Number=09399312213, Called Number=2301, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
Result=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=2301, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=2301
Result=Success(0) after DP_MATCH_DEST
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1005
2: Dial-peer Tag=1006
Jan 29 15:12:01.191: //-1/02820BC8808D/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=09399312213
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=2301
cisco-desttype=4
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Jan 29 15:12:01.191: //-1/02820BC8808D/CCAPI/cc_api_call_setup_ind_common:
Interface=0x14152D7C, Call Info(
Calling Number=09399312213,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=2301(TON=Subscriber, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=pstn, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jan 29 15:12:01.191: //-1/02820BC8808D/CCAPI/ccCheckClipClir:
In: Calling Number=09399312213(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=09399312213(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 29 15:12:01.191: :cc_get_feature_vsa malloc success
Jan 29 15:12:01.191: cc_get_feature_vsa count is 1
Jan 29 15:12:01.191: :FEATURE_VSA attributes are: feature_name:0,feature_time:283524760,feature_id:3044
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=09399312213(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=2301(TON=Subscriber, NPI=ISDN))
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/cc_process_call_setup_ind:
Event=0x1FDF2C0
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 2301
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCallSetContext:
Context=0x1025BD4
>>>>CCAPI handed cid 3053 with tag 3 to app "_ManagedAppProcess_Default"
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCallProceeding:
Jan 29 15:12:01.191: //-1/02820BC8808D/DPM/dpMatchPeersCore:
Jan 29 15:12:01.191: //-1/02820BC8808D/DPM/dpMatchSafModulePlugin:
dialstring=2301, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jan 29 15:12:01.191: //-1/02820BC8808D/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Result=SUCCESS(0)
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=2301, Called Number=2301, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=2301, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1005
Result=SUCCESS(0)
dialstring=2301, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Result=SUCCESS(0)
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=1005, Params=0x101E184, Progress Indication=NULL(0)
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCheckClipClir:
Destination Pattern=23..$, Called Number=2301, Digit Strip=FALSE
Redirect Number=, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=02820BC8-A700-11E4-808D-7426AC5F3A00, Outgoing Dial-peer=1005
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=1
dest=2301
cisco-desttype=4
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x42AC4B50, Interface Type=1, Destination=, Mode=0x0,
Call Params(Calling Number=09399312213,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Called Number=2301(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1005, Call Count On=FALSE,
Source Trkgrp Route Label=pstn, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Jan 29 15:12:01.191: cc_get_feature_vsa count is 2
Jan 29 15:12:01.191: :FEATURE_VSA attributes are: feature_name:0,feature_time:283524984,feature_id:3045
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccCallSetContext:
Context=0x101E134
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccSaveDialpeerTag:
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccGetMediaClassTag:
media class tag 0
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccSetMediaclassIp2ipTags:
media class tags set: NR 0, ASP 0
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccSetMediaclassIp2ipTags:
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccGet_xc_nr_asp_info:
media class tags: NR 0, ASP 0
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccGet_xc_nr_asp_info:
Jan 29 15:12:01.195: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x811F
Jan 29 15:12:01.203: //3054/02820BC8808D/CCAPI/cc_api_set_called_ccm_detected:
CallInfo(called ccm detected=TRUE ccmVersion 3)
Jan 29 15:12:01.203: //3054/02820BC8808D/CCAPI/cc_api_call_proceeding:
Interface=0x42AC4B50, Progress Indication=NULL(0)
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_set_called_ccm_detected:
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_set_delay_xport:
CallInfo(delay xport=TRUE)
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_call_alert:
Interface=0x42AC4B50, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Call Entry(Retry Count=0, Responsed=TRUE)
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
Jan 29 15:12:01.211: //3053/02820BC8808D/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jan 29 15:12:01.211: //3053/02820BC8808D/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Ring Back,
Tone Direction=Network, Params=0x0, Call Id=3053
Calling Number=, Called Number=09399312213, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=09399312213
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:sni
Result=SUCCESS(0)
1: Dial-peer Tag=3
2: Dial-peer Tag=6
Result=SUCCESS(0)
Jan 29 15:12:01.211: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x811F
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_call_notify:
Data Bitmask=0x5, Interface=0x42AC4B50, Call Id=3054
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
Jan 29 15:12:01.211: //3053/02820BC8808D/CCAPI/ccCallNotify:
Data Bitmask=0x5, Call Id=3053
Jan 29 15:12:06.163: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x011F
Cause i = 0x8090 - Normal call clearing
Jan 29 15:12:06.163: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x811F
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x14152D7C, Call Id=3053
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Jan 29 15:12:06.163: //3054/02820BC8808D/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 29 15:12:06.163: //3054/02820BC8808D/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/cc_api_get_transfer_info:
Jan 29 15:12:06.167: //3054/02820BC8808D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x42AC4B50, Tag=0x0, Call Id=3054,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jan 29 15:12:06.167: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 29 15:12:06.167: :cc_free_feature_vsa freeing 10E63F70
Jan 29 15:12:06.167: vsacount in free is 1
Jan 29 15:12:06.211: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x011F
Jan 29 15:12:06.211: //3053/02820BC8808D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x14152D7C, Tag=0x0, Call Id=3053,
Jan 29 15:12:06.211: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 29 15:12:06.211: :cc_free_feature_vsa freeing 10E63E90
Jan 29 15:12:06.211: vsacount in free is 0
Solved! Go to Solution.
01-29-2015 12:09 PM
Try putting the "call-block" command on your POTS dial peer(s). That is where I did it last time.
01-29-2015 12:09 PM
01-30-2015 01:18 AM
Thanks ssh,
That worked although i thought initially it should be applied on the incoming dial-peer as my logs are seeing dial-peer 1005/1006 which are the DP's sending the call to CUCM. The pots DP are outbound so i thought it will check against the calling number which will be the internal DID's.
01-30-2015 01:32 AM
Yes you always block on incoming pots dial-peer thats where the calls land. You dont need to put this command on all pots dial-peer but only the incoming pots dial peer. See from your logs the call is landing on your inbound dial peer 3:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3 <<<<
So as long as you have the block specified on dial-peer 3 it should work.
Hope thats clear.
-Terry
Please rate all helpful posts.
