Blocking inbound calls in H323 with Call Center
wilmer_1282004
I understand there have been lots of posts like this but unfortunately my config is not working even after following those. maybe it is because of call center involved? I am calling the number directly though and we are only sending mainline number to call center so that may not play a role here but im not sure.
Below are my config and debugs and attached is my config (deleted some info not related). Please point out what im missing :(
I configured new voice translation
voice translation-rule 2
rule 1 reject /09399312213/
Created translation Profile
voice translation-profile call_block
translate calling 2
Apply to Incoming Dial-peer
dial-peer voice 1005 voip
description VoIP Dial-Peer to Subscriber
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
destination-pattern 23..$
session target ipv4:10.203.2.116
incoming called-number .
voice-class codec 1
 voice-class h323 1
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
no vad
MAN-VOIP-02#sh run | s dial-peer voice 1006 voip
description VoIP Dial-Peer to Publisher
preference 1
session target ipv4:10.203.2.115
voice-class codec 1
 voice-class h323 1
no vad
DEBUG
MAN-VOIP-02#
Jan 29 15:12:01.187: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x011F
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Calling Party Number i = 0x2181, '09399312213'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '2301'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
        Sending Complete
Jan 29 15:12:01.187: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x811F callID = 0x00B4 switch = primary-net5 interface = User
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=09399312213, Called Number=2301, Voice-Interface=0x14152D7C,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
   Calling Number=09399312213, Called Number=2301, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2301, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2301
   Result=Success(0) after DP_MATCH_DEST
Jan 29 15:12:01.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1005
     2: Dial-peer Tag=1006
Jan 29 15:12:01.191: //-1/02820BC8808D/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=09399312213
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=2301
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 29 15:12:01.191: //-1/02820BC8808D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x14152D7C, Call Info(
   Calling Number=09399312213,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=2301(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=pstn, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jan 29 15:12:01.191: //-1/02820BC8808D/CCAPI/ccCheckClipClir:
   In: Calling Number=09399312213(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=09399312213(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 29 15:12:01.191: :cc_get_feature_vsa malloc success
Jan 29 15:12:01.191:  cc_get_feature_vsa count is 1
Jan 29 15:12:01.191: :FEATURE_VSA attributes are: feature_name:0,feature_time:283524760,feature_id:3044
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=09399312213(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=2301(TON=Subscriber, NPI=ISDN))
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/cc_process_call_setup_ind:
   Event=0x1FDF2C0
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 2301
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCallSetContext:
   Context=0x1025BD4
   >>>>CCAPI handed cid 3053 with tag 3 to app "_ManagedAppProcess_Default"
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCallProceeding:
Jan 29 15:12:01.191: //-1/02820BC8808D/DPM/dpMatchPeersCore:
Jan 29 15:12:01.191: //-1/02820BC8808D/DPM/dpMatchSafModulePlugin:
   dialstring=2301, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Jan 29 15:12:01.191: //-1/02820BC8808D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=2301, Called Number=2301, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 29 15:12:01.191: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2301, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1005
   Result=SUCCESS(0)
   dialstring=2301, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1005, Params=0x101E184, Progress Indication=NULL(0)
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccCheckClipClir:
   Destination Pattern=23..$, Called Number=2301, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=02820BC8-A700-11E4-808D-7426AC5F3A00, Outgoing Dial-peer=1005
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=2301
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x42AC4B50, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=09399312213,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=2301(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1005, Call Count On=FALSE,
   Source Trkgrp Route Label=pstn, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Jan 29 15:12:01.191:  cc_get_feature_vsa count is 2
Jan 29 15:12:01.191: :FEATURE_VSA attributes are: feature_name:0,feature_time:283524984,feature_id:3045
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccCallSetContext:
   Context=0x101E134
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccSaveDialpeerTag:
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccGetMediaClassTag:
   media class tag 0
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccSetMediaclassIp2ipTags:
Jan 29 15:12:01.191: //3054/02820BC8808D/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
Jan 29 15:12:01.191: //3053/02820BC8808D/CCAPI/ccGet_xc_nr_asp_info:
Jan 29 15:12:01.195: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x811F
Jan 29 15:12:01.203: //3054/02820BC8808D/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Jan 29 15:12:01.203: //3054/02820BC8808D/CCAPI/cc_api_call_proceeding:
   Interface=0x42AC4B50, Progress Indication=NULL(0)
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_set_called_ccm_detected:
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_call_alert:
   Interface=0x42AC4B50, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
Jan 29 15:12:01.211: //3053/02820BC8808D/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jan 29 15:12:01.211: //3053/02820BC8808D/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=3053
   Calling Number=, Called Number=09399312213, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=09399312213
Jan 29 15:12:01.211: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:sni
   Result=SUCCESS(0)
     1: Dial-peer Tag=3
     2: Dial-peer Tag=6
   Result=SUCCESS(0)
Jan 29 15:12:01.211: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x811F
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x42AC4B50, Call Id=3054
Jan 29 15:12:01.211: //3054/02820BC8808D/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Jan 29 15:12:01.211: //3053/02820BC8808D/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=3053
Jan 29 15:12:06.163: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x011F
        Cause i = 0x8090 - Normal call clearing
Jan 29 15:12:06.163: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x811F
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x14152D7C, Call Id=3053
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Jan 29 15:12:06.163: //3054/02820BC8808D/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 29 15:12:06.163: //3054/02820BC8808D/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jan 29 15:12:06.163: //3053/02820BC8808D/CCAPI/cc_api_get_transfer_info:
Jan 29 15:12:06.167: //3054/02820BC8808D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x42AC4B50, Tag=0x0, Call Id=3054,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 29 15:12:06.167: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 29 15:12:06.167: :cc_free_feature_vsa freeing 10E63F70
Jan 29 15:12:06.167:  vsacount in free is 1
Jan 29 15:12:06.211: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x011F
Jan 29 15:12:06.211: //3053/02820BC8808D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x14152D7C, Tag=0x0, Call Id=3053,
Jan 29 15:12:06.211: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 29 15:12:06.211: :cc_free_feature_vsa freeing 10E63E90
Jan 29 15:12:06.211:  vsacount in free is 0
shh5455
Level 3
Level 3
Try putting the "call-block" command on your POTS dial peer(s).  That is where I did it last time.
shh5455
Level 3
Level 3
Thanks ssh,
That worked although i thought initially it should be applied on the incoming dial-peer as my logs are seeing dial-peer 1005/1006 which are the DP's sending the call to CUCM. The pots DP are outbound so i thought it will check against the calling number which will be the internal DID's.
Yes you always block on incoming pots dial-peer thats where the calls land. You dont need to put this command on all pots dial-peer but only the incoming pots dial peer. See from your logs the call is landing on your inbound dial peer 3:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=3 <<<<
So as long as you have the block specified on dial-peer 3 it should work.
Hope thats clear.
-Terry
Please rate all helpful posts.
