05-01-2013 08:07 AM - edited 03-16-2019 05:05 PM
We have CUCM 7.1.5.20000-6 and use MGCP. As I recall 8 has a feature to block using translation patterns but not sure if this is possible using versions lower than 8.
So just looking to confirm if CUCM 7.1.5.20000-6 using MGCP can block a call based on the calling party number.
Solved! Go to Solution.
05-01-2013 08:15 AM
Hi Nishant,
You are most correct my friend, with MGCP you need a minimum
of CUCM 8.x
From Dan @ Cisco for MGCP
https://supportforums.cisco.com/docs/DOC-18367
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
05-01-2013 08:18 AM
Hi ,
I think u are looking for Route Next Hop by Calling Party number .
regds,
aman
05-01-2013 08:15 AM
Hi Nishant,
of CUCM 8.x
Cheers!
Rob
"Talk about a dream
- Springsteen
05-01-2013 08:18 AM
Hi ,
regds,
aman
05-01-2013 09:53 AM
That's what I was afraid of.
Thanks for confirming - back to the drawing board!
