Showing results forĀ
Search instead forĀ
Did you mean:Ā
Boot iso 8.6.2.22900 from USB/External Hard disk on MCS server
Yazen Alaa
I have MCS server 7816I5 , i have iso image for 8.6.2.22900 , i want to boot ISO on  the MCS server by USB/external hard disk becasue the image size is exceeded 4.48 and the DVD size is 4.35 so i cant copy the image on DVD
so there is way to solve this issue , or workaround ?
Note : i got this iso image from cisco , it is authorized and it is recommended
Have you tried copying the ISO image to a dual layer DVD? Dual layer DVDs can be up to 8.5GB. The DVD drive on the 7815 should be able to read this with no problem.
HTH. Barry Hesk
Intrinsic Network Solutions.
5 Replies 5
Aman Soi
I think the exact server model is MCS 7816-I5-K9-CMD2.
You can open a TAC case with Cisco .Cisco will open SR with IBM and take help from IBM so as to avoid any violation of warranty issues.
regds,
aman
Anas Abueideh
Level 9
Level 9
is this image bootable ? if you download it from download software page it is not bootable.
Anas
please don't forget to rate the helpful posts
Dear Anas
it is bootable image i got it directly from cisco
how to solve this issue ?
HTH. Barry Hesk
Dear barry
it is done and thanks a lot
