Walkthrough Wednesdays
441
jkittle99
Enthusiast
Breakdown of UCM Roles?
I've seen lots of documentation on how to use multi level access and roles within unified communications manager. It's everywhere.  What isn't 'everywhere' is a breakdown of what each checkbox in the role 'really gives you'.  Some are worded better than others, but it leaves a lot to be desired.  I swear I saw a breakdown once of what they did, but cannot seem to find it. Does anybody know where I might find this document?
Thanks!
1 REPLY 1
The CUCM Admin UI will actually show you what each roll is set to allow.
  1. Choose User Mangement > End User from the menu.
  2. Search for the role you want to review and click on that name hyperlink.
  3. You will see several pages worth of rows. Each row will have two options: read and update. Hopefully these are self-explanatory.
I'm not aware of a document but will attach a link if I run across it.
Content for Community-Ad
Spotlight Awards 2021
