BRI Configuration
Pawan Raut
Level 4
Level 4
I have Cisco 4431 router having NIM-2MFT-T1/E1 will this support 2 BRI line?
If yes what is the configuration should I have to do on router and Call Manager
Vaijanath Sonvane
BRI lines are not supported on NIM-2MFT-T1/E1. You need either NIM-2BRI-NT/TE or NIM-4BRI-NT/TE modules.
Once you have correct interface modules, you can use below BRI configuration guide:
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/b-ConfVoiFxNIM.html
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
No, this is PRI card. For BRI, you need to have NIM-2BRI or NIM-4BRI
***** remember to rate useful posts
