627
dufour001
Beginner
BRI France Telecom
I have 2 CCME in Frans.
With 4 BRI.
I tried to set-up these BRI.
The BRI receive and can place call, but disconnect/reconnect all the time.
On a sh isdn status, most of the time, when there isn't any call, the layer 1 is deactived.
I have other CCME in other countries, and no problem, the layer 1/2 is always up...
I tried with statis tei, dynamic tei, ...
The best result is with tei negotitation first-call, with that, I can place call if the layer 1 is down, that automatically activate it.
But at the end of the call, the BRI is disconnected.
It's on 2 different site, and FranceTelecom has tested the lines, all is ok.
The only think I know from FT is that it's ISDN of type Numeris+.
Is it possible to keep these BRI up ?
Thx
7 REPLIES 7
paolo bevilacqua
Hall of Fame Master
Hi, everywhere in Europe BRI layer 1 is brought down by the CO after a timeout. You cannot change this behavoir.
In consequence of that, the best setting is "isdn tei negotiation preserve". You also need to configure
network-clock-participate WIC x
network-clock-select 1 BRI x/y
repeat this for all ports in decreasing priority.
If still problems, post you configuration and the exact IOS used.
I tried like this.
And also tried with negotiation at first call.
All is good except when I use callforward feature.
With this, I receive the call, CCME try to forward the call (to an external num), and that fail.
opn Q931 debug, I see that the call is rejected.
If I reswitch to static tei, all is good.
When there are multiple BRIs in huntgroup, it's always static tei, sometime telco calls this "PBX".
Did you find the solution?
I have a trunkgroup with 4BRI and only inbound calls work well.
could you send me your configuration? It will be a great help for us ?
thanking you in advance,
He was using a standard configuration:
I tried like this.
Please mention the IOS you are using.
Hi, do you have a dialplan from france? Thanks
paolo bevilacqua
Hall of Fame Master
Already replied in another thread, please open new thread about new problem (beside, I think you had asked this already).
Create
Recognize Your Peers
Content for Community-Ad
