BRI in austria, variable length dialplan
Youssef Aoufi
Level 3
Level 3
Hi all,
I am having some problems configuring a voice gateway in Austria.
The austrian dial plan is variable, so i had to configure overlap-receiving following this document:
https://supportforums.cisco.com/docs/DOC-1343
Now, outgoing and some incoming calls are working fine. But when the call is from landlines the call is not routed correctly.
below my config:
translations:
voice translation-rule 1
rule 1 /^$/ /1013/
rule 2 /43/ /1014/
rule 3 /13/ /1010/
rule 4 /15/ /1001/
rule 5 /16/ /1012/
rule 6 /28/ /1013/
rule 7 /30/ /1005/
rule 8 /32/ /1009/
rule 9 /33/ /1008/
rule 10 /34/ /1011/
rule 11 /45/ /1007/
rule 12 /11/ /1003/
rule 13 /40/ /1004/
rule 14 /29/ /1006/
voice translation-rule 2
rule 1 /1002/ //
rule 2 /1014/ /43/
rule 3 /1010/ /13/
rule 4 /1001/ /15/
rule 5 /1012/ /16/
rule 6 /1013/ /28/
rule 7 /1005/ /30/
rule 8 /1009/ /32/
rule 9 /1008/ /33/
rule 10 /1011/ /34/
rule 11 /1007/ /45/
rule 12 /1003/ /11/
rule 13 /1004/ /40/
rule 14 /1006/ /29/
voice translation-rule 3
rule 1 /^$/ /1002/
rule 2 /43/ /1014/
rule 3 /13/ /1010/
rule 4 /15/ /1001/
rule 5 /16/ /1012/
rule 6 /28/ /1013/
rule 7 /30/ /1005/
rule 8 /32/ /1009/
rule 9 /33/ /1008/
rule 10 /34/ /1011/
rule 11 /45/ /1007/
rule 12 /11/ /1003/
rule 13 /40/ /1004/
rule 14 /29/ /1006/
voice translation-rule 4
rule 1 /^$/ /1003/
voice translation-rule 5
rule 1 /^$/ /1000/
voice translation-profile APPELS_ENTRANTS_BRI0/0/0
translate called 1
voice translation-profile APPELS_ENTRANTS_BRI0/0/1
translate called 3
voice translation-profile APPELS_ENTRANTS_BRI0/1/0
translate called 4
voice translation-profile APPELS_ENTRANTS_BRI0/1/1
translate called 5
voice translation-profile APPELS_SORTANTS
translate calling 2
interfaces
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving T302 4000
isdn twait-disable
isdn point-to-point-setup
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn static-tei 0
interface BRI0/0/1
no ip address
isdn twait-disable
isdn send-alerting
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn twait-disable
isdn send-alerting
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn twait-disable
isdn send-alerting
isdn static-tei 0
voice-port 0/0/0
translation-profile incoming APPELS_ENTRANTS_BRI0/0/0
input gain -1
output attenuation 2
echo-cancel coverage 32
compand-type a-law
cptone AT
timeouts interdigit 5
timeouts wait-release infinity
bearer-cap 3100Hz
voice-port 0/0/1
translation-profile incoming APPELS_ENTRANTS_BRI0/0/1
input gain -1
compand-type a-law
cptone AT
bearer-cap 3100Hz
voice-port 0/1/0
translation-profile incoming APPELS_ENTRANTS_BRI0/1/0
input gain -1
no vad
compand-type a-law
no comfort-noise
cptone AT
bearer-cap 3100Hz
voice-port 0/1/1
translation-profile incoming APPELS_ENTRANTS_BRI0/1/1
input gain -1
no vad
compand-type a-law
no comfort-noise
cptone AT
bearer-cap 3100Hz
dial-peers
dial-peer voice 1 voip
destination-pattern 1...
session target ipv4:172.17.60.13
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2 voip
preference 1
session target ipv4:172.17.60.32
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 3 voip
preference 2
session target ipv4:172.17.60.12
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 10 pots
description utliser pour les appels vers FIXE AUSTRIA
translation-profile outgoing APPELS_SORTANTS
destination-pattern 0[12345678]T
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 11 pots
description utliser pour les appels vers GSM AUSTRIA
destination-pattern 06T
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 12 pots
description utliser pour les appels vers INTERNATIONAL AUSTRIA
destination-pattern 00T
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 13 pots
description utliser pour les appels SPECIAUX AUSTRIA
destination-pattern 81T
direct-inward-dial
port 0/0/0
forward-digits all
prefix 1
dial-peer voice 50 pots
description Dial-Peer For incoming calls         Incoming dial-peer for all incoming calls
incoming called-number .T
direct-inward-dial
dial-peer voice 14 pots
preference 1
destination-pattern 0[1234567]T
direct-inward-dial
port 0/0/1
forward-digits all
dial-peer voice 15 pots
preference 1
direct-inward-dial
port 0/0/1
forward-digits all
dial-peer voice 16 pots
preference 1
direct-inward-dial
port 0/0/1
forward-digits all
dial-peer voice 17 pots
preference 1
direct-inward-dial
port 0/0/1
forward-digits all
prefix 1
please find also the debug showing a call from 013671544 to extension 1010 (DID : 13) .
First we can see that incoming dial-peer is 14 and not 50 ???
Also the number is translated to 1002 and then 13 is appended  so the called number is 100213 and call fails.
MAEC-GW-VIENNE#
*Nov 22 11:38:55.851: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8  callref = 0x01
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8483 - Origination address is non-ISDN
        Date/Time i = 0x0C0B160C29
                Date (dd-mm-yr)   = 12-11-22
                Time (hr:mnt:sec) = 12:41:108
        Calling Party Number i = 0x2183, '13671544'
                Plan:ISDN, Type:National
*Nov 22 11:38:55.855: ISDN BR0/0/1 Q931: TX -> SETUP_ACK pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
*Nov 22 11:38:55.855: //-1/083628E18134/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1002
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Nov 22 11:38:55.855: //-1/083628E18134/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2CC80014, Call Info(
   Calling Number=13671544,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1002(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=14, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
*Nov 22 11:38:55.855: //-1/083628E18134/CCAPI/ccCheckClipClir:
   In: Calling Number=13671544(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=13671544(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
*Nov 22 11:38:55.855: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 11:38:55.855: :cc_get_feature_vsa malloc success
*Nov 22 11:38:55.855:  cc_get_feature_vsa count is 3
*Nov 22 11:38:55.855: :FEATURE_VSA attributes are: feature_name:0,feature_time:732898784,feature_id:1173
*Nov 22 11:38:55.855: //1173/083628E18134/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=13671544(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1002(TON=Unknown, NPI=Unknown))
*Nov 22 11:38:55.855: //1173/083628E18134/CCAPI/cc_process_call_setup_ind:
   Event=0x31773340
*Nov 22 11:38:55.855: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1002
*Nov 22 11:38:55.855: //1173/083628E18134/CCAPI/ccCallSetContext:
   Context=0x2C5161F0
   >>>>CCAPI handed cid 1173 with tag 14 to app "_ManagedAppProcess_Default"
*Nov 22 11:38:55.855: //1173/083628E18134/CCAPI/ccCallSetupAck:
   Call Id=1173
*Nov 22 11:38:55.855: //1173/083628E18134/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
*Nov 22 11:38:55.859: //1173/083628E18134/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x2C504420, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 22 11:38:55.859: //1173/083628E18134/CCAPI/ccCheckClipClir:
   Destination Pattern=1..., Called Number=1002, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=083628E1-33D0-11E2-8134-F0F755D18D68, Outgoing Dial-peer=1
*Nov 22 11:38:55.859: //1173/083628E18134/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1002
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov 22 11:38:55.859: //1173/083628E18134/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x31E2D49C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=13671544,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=1002(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Nov 22 11:38:55.859: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 11:38:55.859: :cc_get_feature_vsa malloc success
*Nov 22 11:38:55.859:  cc_get_feature_vsa count is 4
*Nov 22 11:38:55.859: :FEATURE_VSA attributes are: feature_name:0,feature_time:732897664,feature_id:1174
*Nov 22 11:38:55.859: //1174/083628E18134/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Nov 22 11:38:55.859: //1174/083628E18134/CCAPI/ccCallSetContext:
   Context=0x2C5043D0
*Nov 22 11:38:55.859: //1173/083628E18134/CCAPI/ccSaveDialpeerTag:
*Nov 22 11:38:55.859: //1174/083628E18134/CCAPI/ccGetMediaClassTag:
   media class tag 0
MAEC-GW-VIENNE#
*Nov 22 11:38:55.859: //1174/083628E18134/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Nov 22 11:38:55.859: //1173/083628E18134/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 11:38:55.859: //1174/083628E18134/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Nov 22 11:38:55.859: //1173/083628E18134/CCAPI/ccGet_xc_nr_asp_info:
MAEC-GW-VIENNE#
*Nov 22 11:38:57.039: ISDN BR0/0/1 Q931: RX <- INFORMATION pd = 8  callref = 0x01
        Called Party Number i = 0x81, '1'
                Plan:ISDN, Type:Unknown
*Nov 22 11:38:57.043: //1173/083628E18134/CCAPI/cc_api_call_info:
   Info Digits=1, Info Complete=FALSE,
   Interface=0x2CC80014, Data Bitmask=0x0, Call Id=1173
*Nov 22 11:38:57.043: //1174/083628E18134/CCAPI/ccCallInfo:
   Data Bitmask=0x0, Call Id=1174
*Nov 22 11:38:57.043: //1173/083628E18134/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
MAEC-GW-VIENNE#
*Nov 22 11:38:58.455: ISDN BR0/0/1 Q931: RX <- INFORMATION pd = 8  callref = 0x01
        Called Party Number i = 0x81, '3'
*Nov 22 11:38:58.455: //1173/083628E18134/CCAPI/cc_api_call_info:
   Info Digits=3, Info Complete=FALSE,
*Nov 22 11:38:58.455: //1174/083628E18134/CCAPI/ccCallInfo:
*Nov 22 11:38:58.455: //1173/083628E18134/CCAPI/cc_api_get_called_ccm_detected:
*Nov 22 11:38:58.959: //1174/083628E18134/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x31E2D49C, Call Id=1174
   Call Entry(Responsed=TRUE, Cause Value=18, Retry Count=0)
*Nov 22 11:38:58.959: //1173/083628E18134/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Nov 22 11:38:58.959: //1174/083628E18134/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1174
*Nov 22 11:38:58.959: //1174/083628E18134/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=18)
   Cause Value=18, Call Entry(Responsed=TRUE, Cause Value=18)
*Nov 22 11:38:58.959: //1174/083628E18134/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Nov 22 11:38:58.959: //1174/083628E18134/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31E2D49C, Tag=0x0, Call Id=1174,
   Call Entry(Disconnect Cause=18, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Nov 22 11:38:58.959: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 22 11:38:58.959: :cc_free_feature_vsa freeing 2BAF2178
*Nov 22 11:38:58.959:  vsacount in free is 3
*Nov 22 11:38:58.959: //1173/083628E18134/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2, Params=0x2C5095E0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 22 11:38:58.959: //1173/083628E18134/CCAPI/ccCheckClipClir:
   Destination Pattern=1..., Called Number=100213, Digit Strip=FALSE
   Called Number=100213(TON=Unknown, NPI=Unknown),
   Guid=083628E1-33D0-11E2-8134-F0F755D18D68, Outgoing Dial-peer=2
*Nov 22 11:38:58.959: //1173/083628E18134/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=100213
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov 22 11:38:58.959: //1173/083628E18134/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=100213(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
*Nov 22 11:38:58.959: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 11:38:58.959: :cc_get_feature_vsa malloc success
*Nov 22 11:38:58.959:  cc_get_feature_vsa count is 4
*Nov 22 11:38:58.959: :FEATURE_VSA attributes are: feature_name:0,feature_time:732897664,feature_id:1175
*Nov 22 11:38:58.959: //1175/083628E18134/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 11:38:58.963: //1175/083628E18134/CCAPI/ccCallSetContext:
   Context=0x2C509590
*Nov 22 11:38:58.963: //1173/083628E18134/CCAPI/ccSaveDialpeerTag:
*Nov 22 11:38:58.963: //1175/083628E18134/CCAPI/ccGetMediaClassTag:
   media class tag 0
MAEC-GW-VIENNE#
*Nov 22 11:38:58.963: //1175/083628E18134/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 11:38:58.963: //1173/083628E18134/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 11:38:58.963: //1175/083628E18134/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 11:38:58.963: //1173/083628E18134/CCAPI/ccGet_xc_nr_asp_info:
MAEC-GW-VIENNE#
*Nov 22 11:39:02.059: //1175/083628E18134/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x31E2D49C, Call Id=1175
*Nov 22 11:39:02.059: //1173/083628E18134/CCAPI/ccCallReleaseResources:
*Nov 22 11:39:02.059: //1175/083628E18134/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1175
*Nov 22 11:39:02.059: //1175/083628E18134/CCAPI/ccCallDisconnect:
*Nov 22 11:39:02.059: //1175/083628E18134/CCAPI/cc_api_get_transfer_info:
*Nov 22 11:39:02.059: //1175/083628E18134/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31E2D49C, Tag=0x0, Call Id=1175,
*Nov 22 11:39:02.059: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 22 11:39:02.059: :cc_free_feature_vsa freeing 2BAF2178
*Nov 22 11:39:02.059:  vsacount in free is 3
*Nov 22 11:39:02.059: //1173/083628E18134/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x2C502FB0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 22 11:39:02.059: //1173/083628E18134/CCAPI/ccCheckClipClir:
   Guid=083628E1-33D0-11E2-8134-F0F755D18D68, Outgoing Dial-peer=3
*Nov 22 11:39:02.059: //1173/083628E18134/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=100213
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov 22 11:39:02.059: //1173/083628E18134/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
*Nov 22 11:39:02.059: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 11:39:02.059: :cc_get_feature_vsa malloc success
*Nov 22 11:39:02.059:  cc_get_feature_vsa count is 4
*Nov 22 11:39:02.059: :FEATURE_VSA attributes are: feature_name:0,feature_time:732897664,feature_id:1176
*Nov 22 11:39:02.059: //1176/083628E18134/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 11:39:02.059: //1176/083628E18134/CCAPI/ccCallSetContext:
   Context=0x2C502F60
*Nov 22 11:39:02.059: //1173/083628E18134/CCAPI/ccSaveDialpeerTag:
*Nov 22 11:39:02.063: //1176/083628E18134/CCAPI/ccGetMediaClassTag:
   media class tag 0
MAEC-GW-VIENNE#
*Nov 22 11:39:02.063: //1176/083628E18134/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 11:39:02.063: //1173/083628E18134/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 11:39:02.063: //1176/083628E18134/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 11:39:02.063: //1173/083628E18134/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 11:39:02.455: //1173/083628E18134/CCAPI/cc_api_call_info:
   Info Digits=, Info Complete=TRUE,
*Nov 22 11:39:02.455: //1173/083628E18134/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Nov 22 11:39:02.455: //1176/083628E18134/CCAPI/ccCallInfo:
   Data Bitmask=0x0, Call Id=1176
*Nov 22 11:39:02.455: //1173/083628E18134/CCAPI/cc_api_get_called_ccm_detected:
*Nov 22 11:39:02.455: ISDN BR0/0/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
*Nov 22 11:39:02.531: //1176/083628E18134/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
*Nov 22 11:39:02.531: //1176/083628E18134/CCAPI/cc_api_call_proceeding:
   Interface=0x31E2D49C, Progress Indication=NULL(0)
*Nov 22 11:39:02.531: //1176/083628E18134/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
*Nov 22 11:39:02.531: //1176/083628E18134/CCAPI/cc_api_call_cut_progress:
   Interface=0x31E2D49C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=1
   Call Entry(Responsed=TRUE)
*Nov 22 11:39:02.531: //1173/083628E18134/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=1
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
*Nov 22 11:39:02.531: //1173/083628E18134/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=1173
*Nov 22 11:39:02.535: //1173/083628E18134/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x495, gcid=83628E1-33D011E2-8134F0F7-55D18D68, tag=0x0)
*Nov 22 11:39:02.535: //1176/083628E18134/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x498, gcid=83628E1-33D011E2-8134F0F7-55D18D68, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=1173, Call Id2=1176, Tag=0x0
*Nov 22 11:39:02.535: //1173/083628E18134/CCAPI/cc_api_bridge_done:
   Conference Id=0x99, Source Interface=0x2CC80014, Source Call Id=1173,
   Destination Call Id=1176, Disposition=0x0, Tag=0xFFFFFFFF
*Nov 22 11:39:02.535: //1176/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov 22 11:39:02.535: cc_api_get_xcode_stream : 4819
*Nov 22 11:39:02.535: //1176/083628E18134/CCAPI/cc_api_bridge_done:
   Conference Id=0x99, Source Interface=0x31E2D49C, Source Call Id=1176,
   Destination Call Id=1173, Disposition=0x0, Tag=0x0
*Nov 22 11:39:02.535: //1173/083628E18134/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x99, Destination Call Id=1176)
   Call Entry(Conference Id=0x99, Destination Call Id=1173)
*Nov 22 11:39:02.535: confID:0x99; callEntry1 callID1:0x495, type:6; callEntry2 callID2:0x498, type:1
*Nov 22 11:39:02.535: //1173/083628E18134/CCAPI/cc_api_caps_ind:
   Destination Interface=0x31E2D49C, Destination Call Id=1176, Source Call Id=1173,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Nov 22 11:39:02.535: //1173/083628E18134/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x99, Call Id1=1173, Call Id2=1176
*Nov 22 11:39:02.535: ISDN BR0/0/1 Q931: TX -> PROGRESS pd = 8  callref = 0x81
        Cause i = 0x8181 - Unallocated/unassigned number
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Nov 22 11:39:03.043: //1176/083628E18134/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2CC80014, Destination Call Id=1173, Source Call Id=1176,
   Caps(Codec=0x4, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
*Nov 22 11:39:03.043: //1176/083628E18134/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=7439)
MAEC-GW-VIENNE#
*Nov 22 11:39:03.043: //1173/083628E18134/CCAPI/cc_api_caps_ack:
*Nov 22 11:39:03.043: //1173/083628E18134/CCAPI/cc_api_voice_mode_event:
   Call Id=1173
   Call Entry(Context=0x2C5161F0)
*Nov 22 12:22:40.707: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8  callref = 0x01
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Date/Time i = 0x0C0B160D18
                Time (hr:mnt:sec) = 13:24:108
*Nov 22 12:22:40.711: ISDN BR0/0/1 Q931: TX -> SETUP_ACK pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
*Nov 22 12:22:40.711: //-1/24BF5FA08142/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1002
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov 22 12:22:40.711: //-1/24BF5FA08142/CCAPI/cc_api_call_setup_ind_common:
*Nov 22 12:22:40.711: //-1/24BF5FA08142/CCAPI/ccCheckClipClir:
*Nov 22 12:22:40.711: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 12:22:40.711: :cc_get_feature_vsa malloc success
*Nov 22 12:22:40.711:  cc_get_feature_vsa count is 1
*Nov 22 12:22:40.711: :FEATURE_VSA attributes are: feature_name:0,feature_time:732898112,feature_id:1257
*Nov 22 12:22:40.711: //1257/24BF5FA08142/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Nov 22 12:22:40.711: //1257/24BF5FA08142/CCAPI/cc_process_call_setup_ind:
   Event=0x317728E8
*Nov 22 12:22:40.711: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Nov 22 12:22:40.711: //1257/24BF5FA08142/CCAPI/ccCallSetContext:
   Context=0x2C5124A0
   >>>>CCAPI handed cid 1257 with tag 14 to app "_ManagedAppProcess_Default"
*Nov 22 12:22:40.711: //1257/24BF5FA08142/CCAPI/ccCallSetupAck:
   Call Id=1257
*Nov 22 12:22:40.711: //1257/24BF5FA08142/CCAPI/cc_api_set_transfer_info:
*Nov 22 12:22:40.715: //1257/24BF5FA08142/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=1, Params=0x2C511080, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 22 12:22:40.715: //1257/24BF5FA08142/CCAPI/ccCheckClipClir:
   Guid=24BF5FA0-33D6-11E2-8142-F0F755D18D68, Outgoing Dial-peer=1
*Nov 22 12:22:40.715: //1257/24BF5FA08142/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=1002
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov 22 12:22:40.715: //1257/24BF5FA08142/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 12:22:40.715: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 12:22:40.715: :cc_get_feature_vsa malloc success
*Nov 22 12:22:40.715:  cc_get_feature_vsa count is 2
*Nov 22 12:22:40.715: :FEATURE_VSA attributes are: feature_name:0,feature_time:732897888,feature_id:1258
*Nov 22 12:22:40.715: //1258/24BF5FA08142/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 12:22:40.715: //1258/24BF5FA08142/CCAPI/ccCallSetContext:
   Context=0x2C511030
*Nov 22 12:22:40.715: //1257/24BF5FA08142/CCAPI/ccSaveDialpeerTag:
*Nov 22 12:22:40.715: //1258/24BF5FA08142/CCAPI/ccGetMediaClassTag:
   media class tag 0
MAEC-GW-VIENNE#
*Nov 22 12:22:40.715: //1258/24BF5FA08142/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 12:22:40.715: //1257/24BF5FA08142/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 12:22:40.715: //1258/24BF5FA08142/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 12:22:40.715: //1257/24BF5FA08142/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 12:22:41.499: ISDN BR0/0/1 Q931: RX <- INFORMATION pd = 8  callref = 0x01
*Nov 22 12:22:41.503: //1257/24BF5FA08142/CCAPI/cc_api_call_info:
MAEC-GW-VIENNE#Info Digits=1, Info Complete=FALSE,
   Interface=0x2CC80014, Data Bitmask=0x0, Call Id=1257
*Nov 22 12:22:41.503: //1258/24BF5FA08142/CCAPI/ccCallInfo:
   Data Bitmask=0x0, Call Id=1258
*Nov 22 12:22:41.503: //1257/24BF5FA08142/CCAPI/cc_api_get_called_ccm_detected:
*Nov 22 12:22:42.319: ISDN BR0/0/1 Q931: RX <- INFORMATION pd = 8  callref = 0x01
*Nov 22 12:22:42.319: //1257/24BF5FA08142/CCAPI/cc_api_call_info:
*Nov 22 12:22:42.319: //1258/24BF5FA08142/CCAPI/ccCallInfo:
MAEC-GW-VIENNE#Data Bitmask=0x0, Call Id=1258
*Nov 22 12:22:42.319: //1257/24BF5FA08142/CCAPI/cc_api_get_called_ccm_detected:
*Nov 22 12:22:43.811: //1258/24BF5FA08142/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x31E2D49C, Call Id=1258
*Nov 22 12:22:43.811: //1257/24BF5FA08142/CCAPI/ccCallReleaseResources:
*Nov 22 12:22:43.811: //1258/24BF5FA08142/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1258
*Nov 22 12:22:43.811: //1258/24BF5FA08142/CCAPI/ccCallDisconnect:
*Nov 22 12:22:43.811: //1258/24BF5FA08142/CCAPI/cc_api_get_transfer_info:
*Nov 22 12:22:43.811: //1258/24BF5FA08142/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31E2D49C, Tag=0x0, Call Id=1258,
*Nov 22 12:22:43.811: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 22 12:22:43.811: :cc_free_feature_vsa freeing 2BAF2258
*Nov 22 12:22:43.811:  vsacount in free is 1
*Nov 22 12:22:43.811: //1257/24BF5FA08142/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2, Params=0x2C50AA50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 22 12:22:43.811: //1257/24BF5FA08142/CCAPI/ccCheckClipClir:
   Guid=24BF5FA0-33D6-11E2-8142-F0F755D18D68, Outgoing Dial-peer=2
*Nov 22 12:22:43.811: //1257/24BF5FA08142/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=100213
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov 22 12:22:43.811: //1257/24BF5FA08142/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 12:22:43.811: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 12:22:43.811: :cc_get_feature_vsa malloc success
*Nov 22 12:22:43.811:  cc_get_feature_vsa count is 2
*Nov 22 12:22:43.811: :FEATURE_VSA attributes are: feature_name:0,feature_time:732897888,feature_id:1259
*Nov 22 12:22:43.811: //1259/24BF5FA08142/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 12:22:43.811: //1259/24BF5FA08142/CCAPI/ccCallSetContext:
   Context=0x2C50AA00
*Nov 22 12:22:43.811: //1257/24BF5FA08142/CCAPI/ccSaveDialpeerTag:
*Nov 22 12:22:43.815: //1259/24BF5FA08142/CCAPI/ccGetMediaClassTag:
   media class tag 0
MAEC-GW-VIENNE#
*Nov 22 12:22:43.815: //1259/24BF5FA08142/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 12:22:43.815: //1257/24BF5FA08142/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 12:22:43.815: //1259/24BF5FA08142/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 12:22:43.815: //1257/24BF5FA08142/CCAPI/ccGet_xc_nr_asp_info:
MAEC-GW-VIENNE#
*Nov 22 12:22:46.319: //1257/24BF5FA08142/CCAPI/cc_api_call_info:
*Nov 22 12:22:46.319: //1257/24BF5FA08142/CCAPI/ccCallProceeding:
*Nov 22 12:22:46.319: //1259/24BF5FA08142/CCAPI/ccCallInfo:
   Data Bitmask=0x0, Call Id=1259
*Nov 22 12:22:46.319: //1257/24BF5FA08142/CCAPI/cc_api_get_called_ccm_detected:
*Nov 22 12:22:46.319: ISDN BR0/0/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
*Nov 22 12:22:46.915: //1259/24BF5FA08142/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x31E2D49C, Call Id=1259
*Nov 22 12:22:46.915: //1257/24BF5FA08142/CCAPI/ccCallReleaseResources:
*Nov 22 12:22:46.915: //1259/24BF5FA08142/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=1259
*Nov 22 12:22:46.915: //1259/24BF5FA08142/CCAPI/ccCallDisconnect:
*Nov 22 12:22:46.915: //1259/24BF5FA08142/CCAPI/cc_api_get_transfer_info:
*Nov 22 12:22:46.915: //1259/24BF5FA08142/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31E2D49C, Tag=0x0, Call Id=1259,
*Nov 22 12:22:46.915: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 22 12:22:46.915: :cc_free_feature_vsa freeing 2BAF2258
*Nov 22 12:22:46.915:  vsacount in free is 1
*Nov 22 12:22:46.915: //1257/24BF5FA08142/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x2C508170, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 22 12:22:46.915: //1257/24BF5FA08142/CCAPI/ccCheckClipClir:
   Guid=24BF5FA0-33D6-11E2-8142-F0F755D18D68, Outgoing Dial-peer=3
*Nov 22 12:22:46.915: //1257/24BF5FA08142/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=13671544
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=100213
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov 22 12:22:46.915: //1257/24BF5FA08142/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 12:22:46.915: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 22 12:22:46.915: :cc_get_feature_vsa malloc success
*Nov 22 12:22:46.915:  cc_get_feature_vsa count is 2
*Nov 22 12:22:46.915: :FEATURE_VSA attributes are: feature_name:0,feature_time:732897888,feature_id:1260
*Nov 22 12:22:46.915: //1260/24BF5FA08142/CCAPI/ccIFCallSetupRequestPrivate:
*Nov 22 12:22:46.915: //1260/24BF5FA08142/CCAPI/ccCallSetContext:
   Context=0x2C508120
*Nov 22 12:22:46.915: //1257/24BF5FA08142/CCAPI/ccSaveDialpeerTag:
*Nov 22 12:22:46.919: //1260/24BF5FA08142/CCAPI/ccGetMediaClassTag:
   media class tag 0
MAEC-GW-VIENNE#
*Nov 22 12:22:46.919: //1260/24BF5FA08142/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 12:22:46.919: //1257/24BF5FA08142/CCAPI/ccSetMediaclassIp2ipTags:
*Nov 22 12:22:46.919: //1260/24BF5FA08142/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 12:22:46.919: //1257/24BF5FA08142/CCAPI/ccGet_xc_nr_asp_info:
*Nov 22 12:22:47.347: //1260/24BF5FA08142/CCAPI/cc_api_set_called_ccm_detected:
*Nov 22 12:22:47.347: //1260/24BF5FA08142/CCAPI/cc_api_call_proceeding:
*Nov 22 12:22:47.347: //1260/24BF5FA08142/CCAPI/ccIsInfoRingback:
*Nov 22 12:22:47.347: //1260/24BF5FA08142/CCAPI/cc_api_call_cut_progress:
   Cause Value=1
*Nov 22 12:22:47.347: //1257/24BF5FA08142/CCAPI/ccCallCutProgress:
*Nov 22 12:22:47.347: //1257/24BF5FA08142/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=1257
*Nov 22 12:22:47.347: //1257/24BF5FA08142/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x4E9, gcid=24BF5FA0-33D611E2-8142F0F7-55D18D68, tag=0x0)
*Nov 22 12:22:47.347: //1260/24BF5FA08142/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x4EC, gcid=24BF5FA0-33D611E2-8142F0F7-55D18D68, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=1257, Call Id2=1260, Tag=0x0
*Nov 22 12:22:47.347: //1257/24BF5FA08142/CCAPI/cc_api_bridge_done:
   Conference Id=0xB1, Source Interface=0x2CC80014, Source Call Id=1257,
   Destination Call Id=1260, Disposition=0x0, Tag=0xFFFFFFFF
*Nov 22 12:22:47.347: //1260/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov 22 12:22:47.347: cc_api_get_xcode_stream : 4819
*Nov 22 12:22:47.347: //1260/24BF5FA08142/CCAPI/cc_api_bridge_done:
   Conference Id=0xB1, Source Interface=0x31E2D49C, Source Call Id=1260,
   Destination Call Id=1257, Disposition=0x0, Tag=0x0
*Nov 22 12:22:47.347: //1257/24BF5FA08142/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xB1, Destination Call Id=1260)
   Call Entry(Conference Id=0xB1, Destination Call Id=1257)
*Nov 22 12:22:47.347: confID:0xB1; callEntry1 callID1:0x4E9, type:6; callEntry2 callID2:0x4EC, type:1
*Nov 22 12:22:47.347: //1257/24BF5FA08142/CCAPI/cc_api_caps_ind:
   Destination Interface=0x31E2D49C, Destination Call Id=1260, Source Call Id=1257,
*Nov 22 12:22:47.347: //1257/24BF5FA08142/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xB1, Call Id1=1257, Call Id2=1260
*Nov 22 12:22:47.351: ISDN BR0/0/1 Q931: TX -> PROGRESS pd = 8  callref = 0x81
*Nov 22 12:22:47.755: //1260/24BF5FA08142/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2CC80014, Destination Call Id=1257, Source Call Id=1260,
*Nov 22 12:22:47.755: //1260/24BF5FA08142/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=2464)
*Nov 22 12:22:47.755: //1257/24BF5FA08142/CCAPI/cc_api_caps_ack:
MAEC-GW-VIENNE#
*Nov 22 12:22:47.759: //1257/24BF5FA08142/CCAPI/cc_api_voice_mode_event:
   Call Id=1257
   Call Entry(Context=0x2C5124A0)
MAEC-GW-VIENNE#
MAEC-GW-VIENNE#
MAEC-GW-VIENNE#
*Nov 22 12:22:57.243: //1260/24BF5FA08142/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x31E2D49C, Call Id=1260
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
*Nov 22 12:22:57.243: //1257/24BF5FA08142/CCAPI/ccCallReleaseResources:
*Nov 22 12:22:57.243: //1260/24BF5FA08142/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=1260
*Nov 22 12:22:57.243: //1257/24BF5FA08142/CCAPI/ccConferenceDestroy:
   Conference Id=0xB1, Tag=0x0
*Nov 22 12:22:57.243: confID:0xB1; callEntry1 callID1:0x4E9, type:6; callEntry2 callID2:0x4EC, type:1
*Nov 22 12:22:57.243: //1257/24BF5FA08142/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=1260, Disposition=0x0, Tag=0x0
*Nov 22 12:22:57.243: //1260/24BF5FA08142/CCAPI/cc_api_bridge_drop_done:
*Nov 22 12:22:57.243: //1257/24BF5FA08142/CCAPI/cc_generic_bridge_done:
*Nov 22 12:22:57.243: //1260/24BF5FA08142/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*Nov 22 12:22:57.243: //1260/24BF5FA08142/CCAPI/cc_api_get_transfer_info:
*Nov 22 12:22:57.255: //1260/24BF5FA08142/CCAPI/cc_api_get_transfer_info:
*Nov 22 12:22:57.259: //1260/24BF5FA08142/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x31E2D49C, Tag=0x0, Call Id=1260,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
*Nov 22 12:22:57.259: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 22 12:22:57.259: :cc_free_feature_vsa freeing 2BAF2258
*Nov 22 12:22:57.259:  vsacount in free is 1
*Nov 22 12:22:57.259: //1257/24BF5FA08142/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Nov 22 12:22:57.259: //1257/24BF5FA08142/CCAPI/cc_api_get_transfer_info:
*Nov 22 12:22:57.259: ISDN BR0/0/1 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
        Cause i = 0x8081 - Unallocated/unassigned number
*Nov 22 12:22:57.475: ISDN BR0/0/1 Q931: RX <- RELEASE pd = 8  callref = 0x01
*Nov 22 12:22:57.479: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
*Nov 22 12:22:57.479: //1257/24BF5FA08142/CCAPI/cc_api_call_disconnect_done:
MAEC-GW-VIENNE#Disposition=0, Interface=0x2CC80014, Tag=0x0, Call Id=1257,
*Nov 22 12:22:57.479: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 22 12:22:57.479: :cc_free_feature_vsa freeing 2BAF2338
*Nov 22 12:22:57.479:  vsacount in free is 0
MAEC-GW-VIENNE#ter no mon
MAEC-GW-VIENNE#
you help is much appreciated.
Thank you in advance
5 Replies 5
radoslav-drabik
I had the same issue a while ago. Here is my post.
https://supportforums.cisco.com/message/3377554#3377554
I would amend your config like this:
Incoming called number: 13671544
direct-inward-dial
destination-pattern 1.T                   -> here will be done the digit collection
voice-class codec 1
voice-class h323 1
no vad
"T" timer can be amended under the voice port configuration:
interface BRI0/1/1
no ip address
isdn overlap-receiving T302 4000   -> 4 seconds for "T" timer (that's quite enough, you don't have to change that).
I hope it helps. Please rate.
Hi Radoslav,
I've already read your post a week ago because of a simislar config on Berlin
What i don't undersatnd is why the incoming dial-peer 50 is not matched (incoming called-number .T )
i think the problem is that a translation from null string to 1002 is done before receiving the last two digits (13)
so the final number is 100213.
if the translation is made after digit collection , i think everything will work correctly. But all incoming translation are made at the voice-port before matching the incoming dial-peer.
Try to do this.
permission orig                   -> acts like incoming dial-peer only
port 0/0/0                              -> it makes sure that the dial-peer is matched
direct-inward-dial
Aha. I didn't notice the translation on the voice port 0/0/0. You must remove that in order to get it working and you are right, the translation have to be done on the outgoing dial-peer.
Here is some example. I am not sure if the syntax is correct as I just wrote it by heart.
Incoming called number: 123456
Incoming:
permission orig
description EXAMPLE
port 0/0/0
direct-inward-dial
Outgoing:
translation-profile outgoing profile1
session target ipv4:x.x.x.x
no vad
rule 1 /123\(.*)\/ /100\1/             -> waits for digits and then prefixes the rest of the number with 100
voice translation-profile profile1
translate called 3
