BRI outgoing problem
eljaouhari04
I have BE6ks with a gateway 2921 and two BRI, i have the outgoing problem, tihs is the debug isdn q931:
Aug 17 10:14:33.435: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8  callref = 0x05
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x8A
                Exclusive, B2
        Calling Party Number i = 0x0081, '06????1005'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '0674203819'
Aug 17 10:14:33.483: ISDN BR0/2/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x85
        Channel ID i = 0x8A
                Exclusive, B2
5 Replies 5
Manish Gogna
The calling party number seems to be the issue
Which endpoint is being used as the calling party, what is the DN and External Phone Number Mask specified on the endpoint?
Manish
- Do rate helpful posts -
The DN is 1005 and the external phone number mask is 06XXXXXXXX.
Best regards
Is there any masking at the route pattern , route group or at the gateway level. You can see that the four digits XXXX are being replaced by ???? somewhere in the call flow.
Manish
hi,
this the configuration of the gateway:
gateway#sh run
Building configuration...
Current configuration : 9804 bytes
! Last configuration change at 10:32:57 UTC Mon Aug 17 2015 by cisco
! NVRAM config last updated at 10:34:10 UTC Mon Aug 17 2015 by cisco
version 15.4
hostname gateway
boot-start-marker
boot-end-marker
card type e1 0 1
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-select 1 E1 0/1/0
ip dhcp excluded-address 192.168.1.10 192.168.1.20
ip dhcp excluded-address 192.168.1.244 192.168.1.254
ip dhcp excluded-address 172.27.199.10 172.27.199.20
ip dhcp pool ccp-pool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
domain-name ciscolocal.com
option 150 ip 192.168.1.11
lease 0 2
ip domain name ciscolocal.com
ip host ns.ciscolocal.com 192.168.1.1
ip host ucn1.ciscolocal.com 192.168.1.12
ip host pcp.ciscolocal.com 192.168.1.10
ip name-server 192.168.1.1
ip cef
no ipv6 cef
isdn switch-type primary-4ess
trunk group ALL_PSTN
cts logging verbose
crypto pki trustpoint TP-self-signed-3114885926
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3114885926
revocation-check none
rsakeypair TP-self-signed-3114885926
crypto pki certificate chain TP-self-signed-3114885926
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33313134 38383539 3236301E 170D3135 30343137 31353530
  32345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31313438
  38353932 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DFAA B6C811F2 D22F617C 74DE00C6 DEBFB730 079935B9 B1906BC2 CA229353
  CC71FDD2 557C41F5 B9F21BCE AC34A823 2F4BA033 466FAA63 AA1ED477 9904EE82
  DFA2C8C9 1F1B3E28 7F730BE5 DC2814E6 36F55B9A 4659E232 24649078 9AE18723
  FAC4618B 31EE7908 93DCB78E 8F3EA49B 59B323F5 85C7285F A25B9B0F 55EF85F1
  4BC10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 146A859E 6A65318A A1A58FD2 5F3C7741 7F2C890F 8A301D06
  03551D0E 04160414 6A859E6A 65318AA1 A58FD25F 3C77417F 2C890F8A 300D0609
  2A864886 F70D0101 05050003 81810077 15E75B62 93306F50 78630D69 0CCA387E
  2CBC55D4 064C35F2 EC176DA5 3B87A789 5CED2AC9 CDCEF5A7 EFD3AC45 10693A5E
  DE656AEC 0884424E 29DD6180 1202F8EF A9B369DA 33E0F6AE F4847CBE E13B8946
  FF742C11 C8949AD5 C5636F84 1B7EBA4D 965EC890 894F081D 38224862 25B63E1C
  AA13FF57 BE052C99 36CAB4AA F2432F
        quit
voice-card 0
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 192.168.1.11
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
--More--
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
license udi pid CISCO2901/K9 sn FGL191611G2
hw-module pvdm 0/0
hw-module pvdm 0/1
username cisco privilege 15 secret 5 $1$GHtD$wnwJjzlvzGVQ8P7bjZ2WB.
redundancy
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
controller E1 0/1/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn bind-l3 ccm-manager service mgcp
isdn sending-complete
isdn static-tei 0
trunk-group ALL_PSTN
interface BRI0/2/1
no ip address
isdn static-tei 0
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
control-plane
voice-port 0/0/0
supervisory disconnect anytone
timeouts initial 0
timeouts interdigit 0
timeouts call-disconnect 0
timing hookflash-out 50
timing guard-out 1000
connection plar opx 1010
impedance complex2
bearer-cap 3100Hz
voice-port 0/0/1
supervisory disconnect dualtone mid-call
timeouts initial 0
bearer-cap 3100Hz
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0:15
voice-port 0/2/0
compand-type a-law
description test
bearer-cap Speech
voice-port 0/2/1
compand-type a-law
description test
bearer-cap Speech
mgcp
mgcp call-agent 192.168.1.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 192.168.1.11
ccm-manager config
dial-peer voice 99900990 pots
service mgcpapp
port 0/0/0
dial-peer voice 2 pots
port 0/0/0
dial-peer voice 3 pots
port 0/0/0
dial-peer voice 99900099 pots
service mgcpapp
port 0/0/0
dial-peer voice 5 voip
description utiliser pour les appels entrants extensions 4 chiffres
destination-pattern 1...
progress_ind setup enable 3
progress_ind alert enable 8
session target ipv4:192.168.1.11
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 103 pots
description utliser pour les appels vers les numeros verts
destination-pattern 7T
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 104 pots
direct-inward-dial
port 0/2/0
forward-digits all
dial-peer voice 105 pots
preference 1
direct-inward-dial
port 0/2/1
--More--
gateway
timer receive-rtp 1200
gatekeeper
shutdown
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
gateway#sh run
version 15.4
hostname gateway
boot-start-marker
boot-end-marker
card type e1 0 1
no aaa new-model
import all
lease 0 2
ip cef
no ipv6 cef
cts logging verbose
        quit
voice-card 0
voice rtp send-recv
voice service voip
  ipv4 192.168.1.11
--More--
h323
voice class codec 1
voice class h323 1
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/1/0
controller E1 0/1/1
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
no cdp enable
interface BRI0/2/0
no ip address
isdn static-tei 0
interface BRI0/2/1
no ip address
isdn static-tei 0
ip http server
ip dns server
control-plane
voice-port 0/0/0
timeouts initial 0
impedance complex2
bearer-cap 3100Hz
voice-port 0/0/1
timeouts initial 0
bearer-cap 3100Hz
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0:15
voice-port 0/2/0
compand-type a-law
description test
bearer-cap Speech
voice-port 0/2/1
compand-type a-law
description test
bearer-cap Speech
mgcp
mgcp sdp simple
ccm-manager mgcp
ccm-manager config
service mgcpapp
port 0/0/0
port 0/0/0
port 0/0/0
service mgcpapp
port 0/0/0
codec g711ulaw
no vad
direct-inward-dial
port 0/0/0
forward-digits all
direct-inward-dial
port 0/2/0
forward-digits all
preference 1
direct-inward-dial
port 0/2/1
--More--
gateway
gatekeeper
shutdown
banner exec ^C
this session.
use.
Can you describe what is the problem? Also, is this the full debug? I don't think so because I don't see any release or disconnect messages.
