07-26-2012 10:16 AM - edited 03-16-2019 12:24 PM
Another legacy PBX feature. I have a customer looking at deploying a UC560 to replace their PBX. Currently their PBX will broadcast music supplied by a am/fm receiver connected to the overhead paging system, which is then connected back to the PBX via the Music on Hold input in the PBX box. When there is no active page, the music is broadcast to phones (in which end user have turned on the feature locally) and overhead paging speakers. I talked to Bogen and they have a 70v amplifier that will do the paging/relay break in of the music, however I now need to solve whether the Cisco UC5xx will broadcast overhead paging music to phones if I find a way to input the overhead paging music into the MOH port on the UC 5xx box.
Has anyone run into this? Any solutions?
07-26-2012 10:28 AM
Under which conditions the phones should play MoH ? Normally that only happen when they are put on hold from another extension.
Anything else, it's custom development not covered by standand product feature.
07-26-2012 10:45 AM
Understood, thanks. That is the same response I got from Cisco support. Even on legacy PBX systems this was a custom feature that the vendor rolled up it's sleeves and provided. I am trying to find out if anyone else has paved the way on the customization.
If Cisco wants to win the SMB voice market, they need to continue to provide features that SMB users want or they will continue to lose to Shoretel and Mitel.
07-26-2012 10:56 AM
Can you explain what exactly the feature would be ?
07-02-2014 10:01 AM
Update, we ended up getting this feature to work by installing a Valcom V-9964 Stacking Feedback Eliminator between UC and Paging System.
08-06-2012 03:33 PM
CISCO, any answer to this?
08-06-2012 03:36 PM
If you don't mind explaining the feature in detail first ?
08-06-2012 03:39 PM
Please see my first thread, can't explain it much better than that.
08-06-2012 03:43 PM
Actually you could clarify some, for example,
Does the phones plays music continuosly from the speaker ? And they stop only when a call has to be made ?
And there is a way to mute the music, etc?
If that is, honestly I see zero chances to be developed by Cisco as system feature, however as mentioned before, a custom-developed phone service application may do it
