Bookmark
Subscribe
13053
Bulk delete ITL file
markcarat
Hello
We have two Callmanager clusters.  Both of them is running version 8.5.1.  Let say cluster A has 15 remoote sites and cluster B has 4 remote sites with a total of about 200 7965 phones.  I want to move these 4 remote offices from cluster B to Cluster A, then decommission cluster B.  From CM version Cisco introduce a security reature and install a ITL file on each phone.  In order to move those 200 phone to cluster A, the ITL file must be deleted.  Is there a way we could bulk delete this file?
Mark
3 Accepted Solutions
Aaron Harrison
Hi Mark
Take a look at this document: https://supportforums.cisco.com/docs/DOC-15799
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Stephen Welsh
Level 4
Level 4
The best solution for managing ITL Files (including bulk delete of ITL files remotely) is PhoneView from UnifiedFX, it has the ability to detect, report and if required remotely delete ITL Files. In-fact you can do pretty much anything remotely in just a few mouse clicks using PhoneView.
You can download the free version that works with up to 50 phones for testing and lab use here:
http://www.unifiedfx.com/FileDownload
I've included a video that shows you how can bulk delete multiple ITL Files remotely:
Stephen Welsh
CTO
Ayodeji Okanlawon
Mr Aaron Long time sir Hope you are well...
Mark,
You dont have to worry about deleting ITL files..
You dont have to worry about deleting ITL files, you can consolidate certificates between clusters as long as both clusters are online at the same time, so that the phone certs can be trusted by their new cluster. This another way to go about this. The section "Bulk Certificate Export" in the document Aaron referred you to has the details. The thread below also discussed this and how you can consolidate the certs
https://supportforums.cisco.com/message/3915280#3915280
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
5 Replies 5
Aaron Harrison
Hi Mark
Aaron
Stephen Welsh
Level 4
Level 4
Stephen Welsh
CTO
Ayodeji Okanlawon
Mark,
Thank you for the quick response to Aaron, Stephen and Aokanlawon. I will give it a try and provide feedback.
Mark
imzloy
Found free 30 days software for remote phone control which can delete ITLs, update phone background images etc.: http://www.awnmtech.com/prcut-download/
