Bulk edit Directory Numbers after they have been created
ionicpolarity
Using CUCM 8.5.1 Is the only way to bulk edit directory numbers after they have been created is to export them via "Bulk Administrator"?
I have a range of numbers 78xxx - 78999 that I need to have the boxes checked for "Call forward and Call pickup settings" This was not done at the time of creation, however now I have several voicemail only accounts that cannot be reached internally(when dialed I get a fast busy). In that range I also have accounts that are voicemail and directory as in the number is on the phone. I tried to delete 5 of them under Call Routing/Directory Number as a test and one of the numbers that was on a phone was also deleted when I checked it under Device/Phone. If I delete and recreate them all I will have about 150 of them that I would have to go onto each phone and recreate, which is what I'm trying to avoid.
Brandon Pierce
Level 4
Level 4
Bulk Admin -->  Phones --> Add / Update Lines --> Update Lines --> Search for the range you want and check the box then save.
