08-26-2016 07:32 AM - edited 03-17-2019 07:56 AM
Good Morning,
I have a bunch of phones which I would like to change the Decription, Alerting Name, ASCII Alerting name, Display (Caller ID), ASCII (Caller ID), and Line Text Label. Will I be able to do this with Bulk Edit?
I think I can, but the only questionable field I have a question about is the Line Text Label. Our current labeling scheme is something like:
Antigo Netmeeting (x7790) - x7790 is the extension of this particular phone.
I am looking to change the Line Text Label to Computer Conferencing (x7790). Is it possible to get the extensions added to the Line Text Label with Bulk Edit using some sort of tag or something?
Joe
08-26-2016 08:06 AM
No, you would need to create a custom file with the changes you want to apply in order to change those.
06-18-2017 01:41 PM
I have just done it through bulk but the same value.
Bulk Administration->Phones->Add/Update Lines->Update Lines
06-18-2017 01:41 PM
08-26-2016 08:55 AM
What you need to do is export all details and edit in excel below is the example
>>> PLEASE RATE AND MARK CORRECT AS APPLICABLE<<
Haris
08-13-2019 10:36 AM
Thanks Much Haris for to-the-point solution instead of saying no or yes and not providing the details to resolve the issue like others to get the Cisco points/rating.
