Bulk Update Enable Extention Mobility under Extension Information
samaykhan79
Beginner
Beginner
I was wondering if there is way to do a bulk update/modify for Enable Extension Mobility under Extension Information for phones. Basically there are some users which have the profile selected but we want to edit this in bulk and select " Use Current Device Settings" I am attaching a screen shot. Any help would highly appreciated.
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Yes, BAT has that field available. Update the phones via BAT.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
What if if we need to change the profile or if the user is logged in, can you do "bulk logout" or bulk select " use current Device Settings"
Oops - sorry, wrong post...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Recognize Your Peers
