02-24-2016 04:18 AM - edited 03-17-2019 05:59 AM
I have a client with about 10 000 extensions. They use extension mobility. I need to change all 10 000 extensions from 5-digit to 6-digits. Also, I would need to change the End User telephone number to reflect the new 6-digit range. Looking at the BAT tool I do not see an easy way around this, I would need to export all details for the EM from the CUCM into the BAT then make the changes, then upload, I see many problems with this. Surely there must be a quicker and safer way.
Marcus
02-24-2016 10:03 AM
BAT would be the finest way to do this as the changes needs to be performed in bulk, what are the issues you facing ?
02-24-2016 10:22 AM
The other alternative would be AXL
02-24-2016 10:42 AM
Hi Marcus,
In addition to the good tips from Ven & Java (+5 each) you may want to look at this blog from Bill Bell the UCGUERRILLA;
http://www.ucguerrilla.com/2014/06/using-sql-to-reconfigure-dial-plan.html
Cheers!
Rob
