Business Attendant Console question
etmarcof
Level 3
Level 3
I need only Unified Business Attendant Console.
Is it possible to install them in Receptionist Desktop that meets hardware/software requirements of attendant?
Or do i have to install a dedicated Server and follow server-client arquitecture ?
Best Regards
MC
Jaime Valencia
We do not support having both the server and client on the same HW for any CUxAC.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
In cisco unified attendant consoles design guide says :
In small installations with only one or two Cisco Unified Attendant Console clients, one of the Console
clients is sometimes run on the machine hosting the Cisco Unified Attendant Console server.."
So, now is supported or it works but it's not supported?
Anyone tried that?
Best Regards
MC
