01-28-2014 07:38 PM - edited 03-16-2019 09:29 PM
On CUCM 9.1, I manage to create a call flow where a visitor comes into reception and picks up the Cisco IP Phone which automatically dials a group of extensions using blank Translation Pattern which is associated to the reception phone via a unique Partition.
Can this be done on a BE3000?
Call Flow
Reception IP Phone -> Blank Translation Pattern -> Line Group
01-28-2014 09:17 PM
Yes I think it can be
1) Just create a Unique PT
2) Assign this PT to Blank TP and do Called Party Transformation to XXX --HP--HL-LG--Numbers that you want to send these calls
3) have access to this PT to the reception phone (CSS)
3) once done whenever Reception picks up the phone it will hit the TP and transform to called number to HP--HL-LINEGROUP
whatever member you have associated into this linegroup will ring accordingly basis on .
Try this out and let me know if this work
Br,
Nadeem
Please rate all useful post.
01-29-2014 11:38 AM
Hi Nadeem,
Thanks for the reply. We have a Business Edition 3000 which is not running the CUCM.
Sent from Cisco Technical Support Android App
