Busy Tone
leozin8585
We are having a trouble with all phones "CISCO IP PHONE 7911" when the users try to dial to Provider Services "156" they are getting the busy tone when digit "1".
Is there a configuration on call manager or on the phone we are missing?
Hi Leonardo,
I would configure a few dial-peer like this:
dial-peer voice 1110 pots
description emergency
destination-pattern 015.
port 0/0/1:0
prefix 15
this matches 015X where x is any digit (0-9). So this also works for 156, 154, 158
dial-peer voice 1111 pots
description service number
destination-pattern 0161
port 0/0/1:0
prefix 161
^^ this matches 161
dial-peer voice 1112 pots
description service number 180
destination-pattern 0180
port 0/0/1:0
prefix 180
^^ this matches 180
With configuring this, everybody is able to dial those numbers. If you want to restrict people from dialling those service numbers (maybe not all are free, I dont know), you must apply the appropriate corlist again ("corlist outgoing corlistname" under the dial-peer voice command).
Kai
15 Replies 15
Aaron Harrison
Do you not normally dial 9 for an outside line?
If not it sounds like you are missing a route pattern of some sort. Are you using CME, or Communications Manager? If full CM, are you using a Cisco dial plan or do you have simple route patterns configured?
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks Aaronharrison, I am getting this infos and Let you know asap.
We are using 0 and getting busy tone after that when digit "1".
Run the dialed number analyser with dialed number and you can result why you getting busy tone!!
thanks,
Vipul Jindal
Vipul,
How can I do that? Sorry am new on voice troubleshooting.
you go to cisco serviceability
tools
dialed number analyzer
if you dont see the option than you need to enable 'dialed number analyzer' service from tools --> control center feature service
thanks,
Vipul Jindal
please rate if it helps!!
Our customer said they are using Cisco 3925 as a CM "flash0:c3900-universalk9-mz.SPA.150-1.M6.bin"
Is there a way to troubleshooting and fix it?
so its CME not a call manager.
can you run the below debug and get me the output
debug voip ccapi inout
thanks,
Vipul Jindal
Hi Leonardo,
to me it looks like no dial-peer is matching "0156".
Can provide the output of the "show dialplan-numer 0156" command?
With that output you can see if any dial-peer could match the 0156.
I do not understand your config, because there are a lot of spanish(?) words in the corlists and I am not familiar with your numbering plan.
But maybe you just need to add a new dial-peer like this:
corlist outgoing ChamsGratuitas
description whateveryouprefer
port 0/0/1:0
prefix 15
regards,
Kai
156 is like 911 and etc ...
I Will provide that output
corlist outgoing FreeCalls (Translation)
port 0/0/1:0
prefix 15
Thank You !
CMXYZ01#show dialplan number 156
Macro Exp.: 156
No match, result=-1
CMXYZ01#show dialplan number 0156
Macro Exp.: 0156
No match, result=-1
Hi Leonardo,
ok, if you add the dial-peer I mentioned, just to it like this:
port 0/0/1:0
prefix 15
Just leave the corlist command, because emergency calls should available usually to any phone (even the lobby phones).
regards,
Kai
Further more information, same issue for all free services numbers as: 156, 154, 161, 180 and 158.
We need to create a new dial peer? How to create one dial peer that match all these numbers 156, 154, 161, 180, 158.
Hi Leonardo,
port 0/0/1:0
prefix 15
port 0/0/1:0
prefix 161
^^ this matches 161
port 0/0/1:0
prefix 180
^^ this matches 180
Kai
