11-06-2022 03:55 AM
Good day,
I have a CCME router with some 7945G IP phone, I want access to the (local directory), when I press the Directory button, the IP phone displays (Missed Calls, Received Calls, Placed Calls) it does not display the ( local directory), how can I access to this directory so that I can search for names or extensions.
Best regards,
Solved! Go to Solution.
11-06-2022 09:49 PM
You have turned off the web server service on your gateway by these commands.
no ip http server
no ip http secure-server
You’ll need to at least have one of these, most likely the one for http, set without the “no”.
11-06-2022 04:00 AM
when i press the Directory bouton it desplay :
11-06-2022 04:42 AM
Have you checked this document? Cisco Unified Communications Manager Express System Administrator Guide
11-06-2022 05:00 AM
Yes I checked it, this document says that if I press the (Directory Button) the (local directory) will appear, while this is not my case, my case is if I press the (Directory Button) it displays : (Missed Calls, Received Calls, Placed Calls).
11-06-2022 10:49 AM
Can you please share your running configuration?
11-06-2022 12:08 PM
Router_Data_Voice#show run
Building configuration...
Current configuration : 5248 bytes
! Last configuration change at 18:36:46 UTC Sun Nov 6 2022
! NVRAM config last updated at 18:36:35 UTC Sun Nov 6 2022
version 15.1
hostname Router_Data_Voice
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.40.0.1 10.40.0.10
ip dhcp excluded-address 10.45.0.1 10.45.0.10
ip dhcp pool DATAPOOL
network 10.40.0.0 255.255.255.0
default-router 10.40.0.1
ip dhcp pool VOICEPOOL
network 10.45.0.0 255.255.255.0
default-router 10.45.0.1
option 150 ip 10.45.0.1
voice-card 0
dspfarm
dsp services dspfarm
license udi pid CISCO2921/K9 sn FGL1628137H
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.40
description this will act as DG for the DATA Vlan = 10.40.0.1
encapsulation dot1Q 40
ip address 10.40.0.1 255.255.255.0
interface GigabitEthernet0/0.41
description this will act as DG for the Management Vlan = 10.41.0.1
encapsulation dot1Q 41
ip address 10.41.0.1 255.255.255.0
interface GigabitEthernet0/0.45
description this will act as DG for the VOICE Vlan = 10.45.0.1
encapsulation dot1Q 45
ip address 10.45.0.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
tftp-server flash:apps75.8-3-2-27.sbn
tftp-server flash:cnu75.8-3-2-27.sbn
tftp-server flash:cvm75sccp.8-3-2-27.sbn
tftp-server flash:dsp75.8-3-2-27.sbn
tftp-server flash:jar75sccp.8-3-2-27.sbn
tftp-server flash:SCCP75.8-3-3S.loads
tftp-server flash:term75.default.loads
tftp-server flash:apps45.9-4-2ES26.sbn
tftp-server flash:cnu45.9-4-2ES26.sbn
tftp-server flash:cvm45sccp.9-4-2ES26.sbn
tftp-server flash:dsp45.9-4-2ES26.sbn
tftp-server flash:jar45sccp.9-4-2ES26.sbn
tftp-server flash:SCCP45.9-4-2SR3-1S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:apps37sccp.1-4-5-7.bin
control-plane
mgcp profile default
sccp local GigabitEthernet0/0.45
sccp ccm 10.45.0.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register CONFERENCE
switchover method immediate
switchback method immediate
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 3
sdspfarm tag 1 CONFERENCE
conference hardware
no auto-reg-ephone
max-ephones 50
max-dn 150
ip source-address 10.45.0.1 port 2000
cnf-file location flash:
load 7945 SCCP45.9-4-2SR3-1S
load 7975 SCCP75.8-3-3S
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Nov 06 2022 16:04:42
ephone-template 1
conference drop-mode creator
softkeys seized Endcall Meetme Redial Cfwdall
ephone-dn 1 dual-line
number 4001
label Reception 1
name Reception-1
ephone-dn 2 dual-line
number 4002
label Reception 2
name Reception-2
ephone-dn 3 dual-line
number 4003
label Conference Station MTRoom
name MTRoom
ephone-dn 4 dual-line
number 4004
label Mohamed Zein Maaloum
name Mohamed-Zein-Maaloum
ephone-dn 5 dual-line
number 4005
label Esma Mohamed T'feil
name Esma-Mohamed-Tfeil
ephone-dn 6 dual-line
number 4006
label Aya Mohamed Maloum
name Aya-Mohamed-Maloum
ephone-dn 7 dual-line
number 4007
label Zein Mohamed Maloum
name Zein-Mohamed-Maloum
ephone-dn 8 dual-line
number 4008
label Sidi Mohamed Maloum
name Sidi-Mohamed-Maloum
ephone-dn 9 octo-line
number 3000 no-reg both
conference meetme
ephone-dn 10 octo-line
number AABB no-reg both
conference ad-hoc
ephone 1
mac-address 203A.07FC.310A
ephone-template 1
type 7975
button 1:1 2:4
ephone 2
mac-address 34BD.C8C7.4DF8
ephone-template 1
type 7975
button 1:2
ephone 3
mac-address 0004.F2F2.70CF
ephone-template 1
username "Conference Station MTRoom"
type 7937
button 1:3
ephone 4
mac-address 203A.0722.D66B
ephone-template 1
username "Mohamed Zein El Maaloum"
type 7945
button 1:4
ephone 5
mac-address 203A.0722.1AB4
type 7945
button 1:5
ephone 6
mac-address 203A.0723.B5F6
type 7945
button 1:6
ephone 7
mac-address 203A.0723.B52A
type 7945
button 1:7
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router_Data_Voice#
11-06-2022 01:29 PM
I noticed that by pressing the Directory button at the bottom of the displays (Missed Calls, Received Calls, Placed Calls) there is a message saying (Host Not Fiund) this message takes 10 seconds then it will disappear, I don't know if it can help us find the problem.
View the photo
11-06-2022 01:55 PM
You’ll need to have the web server running on the gateway and configured correctly for CME. That should be part of the documentation shared earlier in another chapter.
11-06-2022 02:20 PM
Router# configure terminal
Router(config)#telephony-service
Router(config-telephony)# url directories http://10.45.0.1/localdirectory
is that what i have to put?
11-06-2022 07:19 PM
ip http server
Router(config)# telephony-service
Enters telephony-service configuration mode.
service local-directory
Router(config-telephony)# service local-directory
enables local directory service on IP phones.
Directory entries
directory entry {directory-tag number name name | clear} !!!... Manually add directory entries
Refer the below guide
11-06-2022 09:49 PM
no ip http server
11-07-2022 03:14 AM
After enabling the http server:
Router_Data_Voice(config)#ip http server
Router_Data_Voice(config)#do write
The problem is solved, the (local directory) is displayed.
View the photo
Thank you very much, you really are an expert.
11-07-2022 04:18 AM
Glad to hear that and thank you for the kind words.
