08-01-2015 03:39 AM - edited 03-17-2019 03:50 AM
Dear all,
I purchased a used Cisco c1861-SRST-C-F/K9 router, which all the configuration are cleared, and the password reset to default. I would like to start playing with it to gain some knowledge.
Unfortunately I have been searching for videos and blogs to get the step by step configuration to setup the devices but I am not finding any. Does anyone could send me a link or some sort of direction to get this devices up and running. Therefore, I succeeded to download the CME 7.1 full.
Many thanks
Ben
Solved! Go to Solution.
08-02-2015 10:44 PM
Look at this link it has got all the details to configure CME, step by step:
https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/6346-102-1-20737/CCNA-Voice%20VoIP.pdf
Some videos on you-tube:
https://www.youtube.com/watch?v=V7yEHz2tj64
https://www.youtube.com/watch?v=TKSjMs297zI
-Terry
Please rate all helpful posts
08-02-2015 10:44 PM
-Terry
08-04-2015 11:23 AM
Dear terry,
Thank you very much, these are very useful and what I needed,
Ben
