C200M2 VMWare 5.0.0U1 instalation - Disk not detecting
rajesh.kumar
Level 4
Level 4
I am installing VMWare 5.0.0.U1 on UCS C200M2
It has 8 number of 149GB HD
but during VMWare installation I am getting below screenshot and when I press enter, nothing happens.
No other way than cancel the installation.
Pls. suggest
Rgds
Rajesh
Jaime Valencia
Have you already configured the RAID??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Dear Java
This problem is resolved using UCS utility tool DVD that ships with UCS server.
RAID was not configured. Once RAID configured using utility tool. We are able to install VMWare.
Some cases server comes with RAID installed, some cases it is not.
Thanks a lot
Rgds
Rajesh
