C2901, MGCP and SRTP ?
i have on Router 2901 is working as a PSTN Gateway with MGCP to UCM 8.6.2. All it's working fine. But i cannot enter the connand:
mgcp package-capability srtp
dt-ccm-sbhkw-vgw-001(config)#mgcp package-capability ?
  as-package      Select the Announcement Server Package
  atm-package     Select the ATM Package
  dtmf-package    Select the DTMF Package
  fm-package      Select the FM Package
  fxr-package     Select the FXR Package
  gm-package      Select the Generic Media Package
  hs-package      Select the Handset Package
  it-package      Select the IT Package
  line-package    Select the Line Package
  mdr-package     Select the MDR Package
  mf-package      Select the MF Package
  pre-package     Select the PRE Package
  res-package     Select the RES Package
  rtp-package     Select the RTP Package
  script-package  Select the Script Package
  sst-package     Select the SST Package
  trunk-package   Select the Trunk Package
The IOS is c2900-universalk9-mz.SPA.151-3.T1.bin. I tried other Version within T-Train. Alos teh UC-Feature are licensed. Why ist the srtp Feature not available?
thx and regards
Ronny
Aman Soi
Hi Ronny,
I think u should have a security image installed on ISR G2 router since on ISR series u require Advanced IP Services or Advanced Enterprise Services image.
can u try loading a security image with Eval licnese?
regds,
aman
Hi Aman,
with Universal Image in Train 15.x we have no distiction between Advanced IP and Base IP etc. The UC Licenses are enabled, security not. How can i enable shis?
regards
Ronny
Hi Ronny,
You need to have an image which has UC,Data and Security enabled.Please find the snapshot which I have captured from Cisco Feature NAvigator.
You can get the Evaluation security licnese by cisco.com/go/license by enetring Serial number and UDI of router.Thereafter, u need to buy from Cisco.
You can just the desired command.
regds,
aman
Hi Ronny,
In addition to what I have said,you can activate the licenses using this URL?
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html
regds,
aman
