C2901 WIC module not supported/disabled in this slot
rinoseo1017
I connected WIC card.. and it doesn't work...
when i check sh iag, it says WIC module not supported/disabled in this slot
should i upgrade IOS? or is there any way to solve it?
Router#sh diag
Slot 0:
C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 00:21:54 ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC1931B7MT
Hardware Revision : 1.0
Part Number : 73-11834-12
Top Assy. Part Number : 800-30795-06
Board Revision : H0
Deviation Number : 0
Fab Version : 03
Product (FRU) Number : CISCO2901/K9
Version Identifier : V06
CLEI Code : CMMJA00ARA
Processor type : C1
Chassis Serial Number : FGL193420WK
Chassis MAC Address : 5c83.8fe3.1580
MAC Address block size : 72
Manufacturing Test Data : 00 00 00 00 00 00 00 00
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 39 33 31 42 37 4D 54 40
0x10: 06 17 41 01 00 82 49 2E 3A 0C C0 46 03 20 00 78
0x20: 4B 06 42 48 30 88 00 00 00 00 02 03 CB 8C 43 49
0x30: 53 43 4F 32 39 30 31 2F 4B 39 89 56 30 36 20 D9
0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 4A 41 30 30 41 52
0x50: 41 09 C1 C2 8B 46 47 4C 31 39 33 34 32 30 57 4B
0x60: C3 06 5C 83 8F E3 15 80 43 00 48 C4 08 00 00 00
0x70: 00 00 00 00 00 F3 00 65 40 01 25 41 00 87 42 00
0x80: 00 F8 00 28 03 E8 1C 89 07 D0 20 21 0B B8 20 93
0x90: 0F A0 21 2F 13 88 21 83 17 70 21 A8 1B 58 21 B0
0xA0: 1F 40 21 AB 23 28 21 79 27 10 21 78 41 01 1D 42
0xB0: 00 00 F8 00 28 03 E8 1C 20 07 D0 1F 40 0B B8 20
0xC0: 6C 0F A0 21 34 13 88 21 34 17 70 21 98 1B 58 21
0xD0: 98 1F 40 21 98 23 28 21 34 27 10 21 34 FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
Part Number : 73-11576-03
Board Revision : D0
Fab Version : 03
PCB Serial Number : FOC19320B9R
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM3-16
Version Identifier : V01
0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 44 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 39 33 32
0x20: 30 42 39 52 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Serial 2T (12in1)
Hardware revision 1.0 Board revision B0
Serial number 36866380 Part number 800-03181-03
Version Identifier V01 FRU Part Number WIC-2T
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 02 32 89 4C 50 0C 6D 03 00 00 00 00
0x30: 58 00 00 00 09 03 28 00 FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
Total platform memory : 524288K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x80000000
Virtual address start of 2nd core memory : 0x0 - 0x0
2nd core configured disabled
L2 cache ways for 2nd core : 0
Router#
Router#
Router#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.3(3)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 04-Aug-15 03:59 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Router uptime is 22 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.153-3.M6.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL193420WK
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2901/K9 FGL193420WK
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
NtwkEss None None None
CollabPro None None None
Router#
Router#
Router#sh inven
NAME: "CISCO2901/K9", DESCR: "CISCO2901/K9 chassis, Hw Serial#: FGL193420WK, Hw Revision: 1.0"
PID: CISCO2901/K9 , VID: V06 , SN: FGL193420WK
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16 , VID: V01 , SN: FOC19320B9R
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC , VID: , SN:
Router#
Aman Soi
Leo Laohoo
WIC-2T is replaced by HWIC-1T/HWIC-2T.
