09-10-2008 06:11 PM - edited 03-15-2019 01:11 PM
Can someone supply a good example of CatOS C2948 config for QoS for voice?
I've been unsuccessful at finding a good config guide on CCO.
Thanks!
09-10-2008 08:25 PM
hi Michael
this is what u look for
Configure CatOS Catalyst Switches to Connect Cisco IP Phones Configuration Example
if helpful Rate
09-11-2008 02:16 AM
I'm actually looking for some doc that specifically tells about how the port queues are to be set up. The version of CatOS doesn't support Auto Qos, so I need to build out the queue(s). I found one doc that mentioned queues, but it is cryptic....what are the weights? What do I weigh COS 4 and 5? Weight 4? Does that put those packets in Pq?
