ā06-03-2012 06:22 AM - edited ā03-16-2019 11:28 AM
We are getting the below error "%C5510-1-NO_RING_DESCRIPTORS" and isdn channels goes up/down, the Voice gateway is working for the past 3 years without any issuse ?.
Please light me the issuse is because of PVDM or we need to upgarde IOS, the current IOS is 12.14(15).
ā06-03-2012 08:23 AM
Did you see this:
ā06-03-2012 09:11 AM
Another matching bug:
CSCsr56105
Symptoms: A Cisco IOS VoIP gateway may experience audio issues such as dead- air or one-way audio for VoIP call present on the gateway. When this occurs, the following error message will be displayed on the gateway: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors available
Conditions: The symptom is observed on a Cisco 2801 VoIP gateway that is running Cisco IOS Release 12.4(20)T or Release 12.4(15)XZ1.
Workaround: There is no known workaround to prevent this issue while using Cisco IOS Release 12.4(20)T or 12.4(15)XZ1 while using the Cisco 2801 router. Use an earlier release to avoid this issue.
ā06-03-2012 09:12 AM
The voice router has been working perfectely for the past 3 years, from today moring it has the above issuse. Current IOS version 12.4(14)T.
It is becuase of IOS or the DSP [ hardware itself ] ?
