02-25-2011 08:53 AM - edited 03-16-2019 03:38 AM
Good day, all -
I'm hoping for an easy resolution...
We've just bought a CP-7962G phone, but CCM 4.1 does not recognize it. I understand I need to install the firmware for this phone in the TFTP directory, but I've been unable to unearth a task-specific document (aka "how-to") telling how to accomplish the task.
Any assistance will be gratefully received!
Thanks...
Solved! Go to Solution.
02-25-2011 09:05 AM
Hi Thomas,
When the required Device is not shown on the Device Defaults page then a
new Device Pack (not just the firmware) will need to be loaded to add support for the new IP Phone
7962 model
You would need at least Device Pack 4.1.65 which is compatible with CCM 4.1(3)SR1
Cisco Unified CallManager Device Package 4.1(65.0) Release Notes
http://www.cisco.com/web/software/Voice/html/ciscocm.4-1-DevPack-65.readme.html
Note: It is very important to disable platform agents and services, such as NetIQ and Prognosis performance monitoring, Cisco-verified antivirus services and intrusion detection software, remote management services, and any other monitoring applications that automatically restart services; this action ensures that your system does not encounter issues that are associated with these services.
Note: To verify that the installation completed successfully, follow the instructions in Step 5 in the Installation Instructions section.
Note: Cisco recommends that you apply this Device Package during a maintenance window.
Procedure
NOTE: Apply this patch to all of your Cisco CallManager servers, beginning with the publisher server and TFTP server.
When applying this Device Package to enable new device support, a cluster-wide reboot is required for those devices to register successfully. A clusterwide reboot IS NOT required when running to update existing firmware/support.
If installing on a Cisco Unified CallManager version earlier than 4.1(3)sr2, the following message will be displayed: “Install on all nodes is required. All nodes will be rebooted as part of the installation.”
If installing on Cisco Unified CallManager 4.1(3)sr2 (recommended), the following message will be displayed: "Install on Publisher and TFTP server is required. Installation on all nodes is highly recommended." A clusterwide install/reboot is required.
Perform the following procedure to install Cisco Unified CallManager Device Package X.X.exe:
1. Download the ciscocm-4-1-DevPack-X.X.exe file to your hard drive. Make a note of the location where you saved the file.
2. Double-click on the downloaded file to begin the installation.
3. Click Yes when the installation process displays a message that asks if you want to install this Device Package.
4. The remainder of the installation process continues without any additional user input.
5. Towards the end of the install it will prompt you "Update ALL devices firmware defaults?", (IMPORTANT) If you click "yes", it will change the default firmware load for all devices to the latest load packaged with this device pack, click "no" if you want to change the loads manually yourself later.
Note: In order to change the loads manually, you do NOT need to reinstall this Device Package. The new files will be present in the C:\Program Files\Cisco\TFTPPath folder. Go to CCMAdmin->System->Device Defaults and manually change the name of the load file (for specific device(s)) to the new load and click UPDATE. Next, reset the affected devices for them to upgrade to the new load.
The system will ask you if you want to view the logfile when the installation is complete.
6. Verify that the installation completed successfully by taking the following actions:
a. When the system prompts you to view the log file, if the number of errors listed in the dialog is "0", you can select No.
b. If the number of errors detected was greater than 0, select Yes to view the logfile and scroll down to the end of the log file. The errors section at the bottom of the log file will be updated with a corresponding severity.
c. Reset affected devices in order for them to obtain new firmware loads, or reboot the cluster.
Note: If the TFTP server is a separate server from the Publisher, the Cisco TFTP service needs to be stopped and restarted on the TFTP server before performing this step, unless the cluster (including the TFTP server) is being rebooted.
Cheers!
Rob
02-25-2011 09:12 AM
Hi Thomas,
Roy's method would also work (+5 Roy )
You would need at least Cisco Unified Communications Manager Versions 4.1(3)sr5b
Cheers!
Rob
02-25-2011 09:04 AM
Maybe you can try to upgrade all your CCM to a newer version in 4.1.
When you do that, you upgrade de firmware and maybe you will have more models of Phones to use.
02-25-2011 09:05 AM
Hi Thomas,
7962 model
Procedure
Cheers!
Rob
02-28-2011 07:46 AM
Rob & Roy -
Thanks to both for providing direction... Looks to be bigger than I'd thought, but nothing I can't deal with; I'll be working on Sunday afternoon, it looks like.
Tom Harper
02-25-2011 09:12 AM
Hi Thomas,
Cheers!
Rob
