03-25-2018 03:29 PM - edited 03-17-2019 12:29 PM
we have CUCM cluster contain HQ site and 20 sites , how can we achieve below requirements by CAC .
as example we have these Sites A,B,C,D,E
1- Max simultaneously Calls between two sites is 5 calls (Calls between site A and Site B )
2- Max simultaneously Calls between one site and Multisite is 5 calls (Calls between Site A and Sites B,C,D,E )
Remon
Solved! Go to Solution.
03-26-2018 07:48 PM
03-25-2018 04:56 PM
Ramon,
CAC is very much tied to the bandwidth you assign to a location. so for 5xG711 calls, you will need to set aside 5x80kbps=400 kbps. (so G711+overhead)
this means the 6th call will be routed using AAR across the PSTN (which might not be usefull if you use centralised SIP).
really the remote site does not care where the call goes to. it just looks at its own location.
03-26-2018 02:48 AM
You can create a location called MPLS which simulates a cloud. Then each location should have a link to the MPLS cloud. Last make sure that the BW between Location A and MPLS is suitable for 5 calls as mentioned below by Dennis (example 5 G729 calls need 120).
For site-B, create a direct link between location A-B and have the BW on it for 5 calls.
03-26-2018 04:02 AM
Hello Mohamed ,
I can't get how this achieve my scenario ,to be clear
we have 20 branches and HQ sites what we need is :-
HQ site can make about 100 simultaneous calls over wan to all branches but max 5 simultaneous calls to each branch .
Each Branch (EXP Branch A)can make max 5 call over wan (may this 5 call to branch B ) or (may these 5 calls divided to 2 calls to Branch B and the other 3 calls to Branch C so if branch A try to make 6th call ,this call will be dropped even if branch A try to call another Branch (Exp Branch D )
Remon
03-26-2018 07:48 PM
03-26-2018 10:44 PM
Hello Mohamed
So as per your recommendation and Dennis reply ,
CAC does not care where the call goes to. it just looks at source location of calls .Right or not ?
If it's right , i think we will face issue when HQ-site try to make simultaneous 10 calls to BR-A , it will success even the max calls from BR-A to MPLS is 5 and this will not achieve what we need .
03-26-2018 11:00 PM
