CAD agents disconnected with minor netowrk disruption
Does anyone know of a way to increase the resiliancy of the CAD/CSD applications in reguards to their network connectivity. iT seems that very minor network disruptions cause the server to drop all the agents at one of our sites for the slightest network slowdown or lag. No other applications that they are using have any issues, and usually the network issue isnt even enough for our routers and gateway to log anything. Is there some timeout setting we can adjust to make this thing happier?
I don't believe that you have to change the timeouts, but I recommend you follow the recommended QoS policys for ICM/IPCC, this may help you a little with your trouble.
Attracted by the concept of dial plan and the passion of writing, I launched a challenge to write a workbook with practical scenarios covering in details this concept, the result is a workbook with 30 practice labs treating many components such route patt...
view more
Understanding Media Negociation in Interworking / Traversal Call : SIP <-> H323 through Expressway. Inside SDP and H245. Both signaling and Media goes through the Expressway so the IP address of expressway is offered to both SIP and H.323 endpoin...
view more
Sometimes you troubleshoot the phone presence status issue, or you are wondering how the status is retrieved by IMP, the best place to start is to look at the SIP Publish message sent by the CUCM to IMP, Capture the SIP Publish message using wireshark, in...
view more
The translation pattern is the most important tool in the Call Routing Process on Cisco Unified Communication manager.By definition a Translation Pattern is used to match the DIALED NUMBER (CALLED). After a match is found we perform a digits manipulation....
view more
Sometimes, you want to populate the Self Service User ID and the Primary Extension + the Conference Now Meeting Number automatically with the IpPhone or Telephone Number LDAP Attribute used in the LDAP Directory configuration page when importing AD users ...
view more
