call disconnect
elite2010
Level 3
Level 3
I have the following  problem ,
I am calling one line ,
then dialing another line  then pressing conference , the second line disconnects
Problem 2 :
then dialing another line  for confernece , second line disconnects
What could be the problem ?
conference call has any relation with CSS
Jaime Valencia
I'm going to assume this is CUCM as you say CSS.
Does the phone has access to a CFB? And does the CFB supports the codecs you're using?
java
if this helps, please rate
