203
Beginner
Call disconnects everytime after 10 minutes
What do I need to check?
Are there any settings?
thanks in adv,
joel
3 REPLIES 3
Hall of Fame Community Legend
Re: Call disconnects everytime after 10 minutes
Hi Joel,
Is this all calls Incoming and Outgoing? If this is CCM you could check;
Maximum Call Duration Timer (number of minutes)
CCMAdmin > Service > Service Parameter > Cisco CallManager > Advanced >Clusterwide Parameters (Feature - General)
The default for this setting is 720 minutes. Perhaps this has been changed.
Hope this helps!
Rob
Highlighted
Beginner
Rob,
That was set to the default...thanks for the pointer through...
I've opened a TAC case now....
joel
Contributor
is it an MGCP gateway? if so have you done the no mgcp timer command?
Content for Community-Ad
August's Community Spotlight Awards
