01-27-2014 08:14 AM - edited 03-16-2019 09:27 PM
Good morning - I have a user who is trying to dial out to a 802 and 870 area codes. The calls will not complete. After he dials the number, the call just hangs in limbo. We have tried dialing other numbers with these area codes and the calls complete so it should not be in the route pattern. Since the call does not complete, I cannot see it in the CDR logs. Is there another way to view where the call is hanging? I am not very familiar with looking at the CISCO logs but could if I knew which log to look at.
All other long distance calls to other area codes complete normally.
Thanks for any insights.
Pat
Solved! Go to Solution.
01-27-2014 08:44 AM
you can make a test call and capture the 'debug isdn q931' logs from the GW now. Please include the calling & called numbers.
Please rate all the useful posts
01-27-2014 08:20 AM
Hi Pat,
what is the call flow? ex: IP phone---sccp---CUCM----H.323/MGCP GW----T1 PRI-----PSTN?
- we need to check whether the calls are hitting the GW
- if no, it could be css issue.
- if it is coming to GW, we need to check who is disconnecting the call by taking relevant logs.
//Suresh
01-27-2014 08:42 AM
The call flow example is correct. I am not sure how to tell if the call is hitting the gateway.
01-27-2014 08:44 AM
01-27-2014 12:07 PM
This issue has resolved itself. The problem was with the telco. Thank you for your help.
