call doesnt get to PSTN
andres.pasten
I´ve a rare issue. I've a Cisco 2821 as gateway with 3 E1, two connected to PSTN and the last one connected to an IVR.
a) E1-PSTN
interface Serial1/0/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
b) E1-IVR
interface Serial0/0/0:15
description E1 IVR MKD
no ip address
isdn protocol-emulate network
isdn bchan-number-order descending
no cdp enable
I can make calls from the PSTN to a number assigned to the E1-IVR, but when a call to E1-PSTN comes from the E1-IVR, it receives ringback tone but the call is not sended to the PSTN. These are the dial-peers:
1.- E1-PSTN
dial-peer voice 900 pots
preference 1
destination-pattern 9.......
incoming called-number .
fax rate disable
direct-inward-dial
port 1/0/0:15
forward-digits 7
2.- E1-IVR
dial-peer voice 6432 pots
destination-pattern 6432
fax rate disable
direct-inward-dial
port 0/0/0:15
forward-digits all
Here is a debug for a call from PSTN to IVR:
*Aug  3 17:05:50.997: ISDN Se1/0/1:15 Q931: RX <- SETUP pd = 8  callref = 0x020E
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA1838B
                Preferred, Channel 11
        Calling Party Number i = 0x2183, '28385500'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '5826432'
                Plan:ISDN, Type:Subscriber(local)
*Aug  3 17:05:51.009: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 28385500
*Aug  3 17:05:51.009: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Called num 6432
*Aug  3 17:05:51.009: ISDN Se1/0/1:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x820E
        Channel ID i = 0xA9838B
                Exclusive, Channel 11
*Aug  3 17:05:51.009: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x6052
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0xC1, '6432'
*Aug  3 17:05:51.033: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xE052
*Aug  3 17:05:51.033: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xE052
        Progress Ind i = 0x8182 - Destination address is non-ISDN
*Aug  3 17:05:51.037: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected to 6432 N/A
*Aug  3 17:05:51.037: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x6052
*Aug  3 17:05:51.041: ISDN Se1/0/1:15 Q931: TX -> CONNECT pd = 8  callref = 0x820E
*Aug  3 17:05:51.093: ISDN Se1/0/1:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x020E
*Aug  3 17:05:51.093: %ISDN-6-CONNECT: Interface Serial1/0/1:10 is now connected to 28385500 N/A
and here is a debug for a call from IVR to PSTN:
*Aug  3 17:01:14.317: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0013
                Standard = CCITT
        Channel ID i = 0xA18381
        Calling Party Number i = 0x4180, '6432'
        Called Party Number i = 0xC1, '95853444'
        Sending Complete
*Aug  3 17:01:14.329: ISDN Se1/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Calling num 6432
*Aug  3 17:01:14.333: ISDN Se1/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Called num 5853444
GW-LCOCHRANE#
GW-LCOCHRANE#
GW-LCOCHRANE#
*Aug  3 17:01:14.333: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8013
        Channel ID i = 0xA98381
*Aug  3 17:01:14.333: ISDN Se1/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x6049
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
        Called Party Number i = 0xC1, '5853444'
*Aug  3 17:01:14.377: ISDN Se1/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xE049
*Aug  3 17:01:14.409: ISDN Se1/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xE049
        Progress Ind i = 0x8282 - Destination address is non-ISDN
        Progress Ind i = 0x8288 - In-band info or appropriate now available
On both cases, the calls move from one E1 to the other, but on the second case the call remain on the E1.
The only difference that I've find is on the called party number type. Any hint would be helpfull
TIA
Andres Pasten
Adexus S.A.
Andres
Thanks for the logs and clarification , the call is disconnected since the IVR user drop the line :
*Aug 9 14:51:02.237: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x000A
Cause i = 0x8190 - Normal call clearing
That’s because there was no progress in the call from the pstn side , even the pstn user didn’t answer the call but the but the ivr user didn’t wait till they send disconnect msg , or the user answer but they are not able to send the appropriate msg , see below :
We sent setup :
We sent setup with sending completet flag for them to start routing the call :
*Aug 9 14:50:45.637: ISDN Se1/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x06A9
Sending Complete
Standard = CCITT
Calling Party Number i = 0x4180, '6722'
Called Party Number i = 0xC1, '6861309'
Then they sent proceed :
Aug 9 14:50:45.685: ISDN Se1/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x86A9
Now we received alerting with inband info (ringback )
*Aug 9 14:50:45.717: ISDN Se1/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x86A9
*Aug 9 14:50:45.717: //7220/CC0200F787ED/CCAPI/cc_api_call_alert:
Interface=0x46AC2220, Progress Indication=DESTINATION IS NON ISDN(2), Signal Indication=SIGNAL RINGBACK(1)
Then the call now is pending on the isdn to send connect message which is not done , please refer to your isdn provider for investigation .
Let me know if any clarification .
-- haitham
10 Replies 10
hzaben
Andres
few questions :
- what's the call flow in both ? smthing like ip-phone --> CUCM --> h323 --> GW --> e1 0/0/0 --> isdn --> back to e1 1/0/0 --> h323 --> CUCM
- can you share :
*show run / show version
* for two test calls (working and non-working)
debug voice ccapi inout
debug h225 asn1
debug isdn q931
debug h245 asn1
please specify the call info for the above
regards,
haitham
Haitham,
Thanks for your reply, I´ll have tomorrow the requested debugs.
1.- But for now I can tell you that the flow for the working call is:
PSTN -> E1 1/0/0 -> GW -> E1 0/0/0 -> IVR
that´s when you call the DN 6432 that is defined on IVR
2.- The inverse flow, that´s when DN 6432 wants to call any PSTN number, is not working.
See you.
Andres
I'm not sure this will help , but give it a try , under your dialpeer add
Router(config-dial-peer)#numbering-type unknown
I've tried, but this command operates as a filter rule. For example, if I set numebring-type to unknown, it only permit unknown calls to pass. And the calls arrives marked as Subscriber, so it only pass when I set numbering-type to subscriber.
However, anyone know why this set can prevent a call to be sended to PSTN?
Thanks anyway.
Andres Pasten
Haitham,
I´ve uploaded the requested files.
Please let me know if you find something.
TIA
Andres Pasten
Andres
Why I’m seeing h225 if the call flow like u mentioned above ? can you clarify the exact call flow pls ?
Also you entered the debugs separately , I need to debug all the requested then to make the call if you can .
Haitham
Haitham,
I'll get the debugs later, because there is a lot of traffic to isolate the calls. I understood that you need the debugs one per time, sorry.
And about the traffic, this are calls that goes from one E1 to another E1:
a) Incoming call:
1) Someone on PSTN calls to 5826432
2) The call arrives to E1 1/0/0 or 1/0/1 (that are connected to PSTN)
3) Then traslation rule applies, dropping the first 3 digits, remaining the call to 6432
4) Then dial-peer voice 6432 pots applies, sending the call to E1 0/0/0 connected to IVR
5) Call is received ok on IVR, establishing conversation
b) Outgoing call:
1) Someone on IVR dials to PSTN using 9 as prefix, on example 96861315 is dialed
2) The call arrives to E1 0/0/0 (that is connected to IVR)
3) Then dial-peer voice 900 pots applies, sending the call to E1 1/0/0 connected to PSTN, and dropping the prefix 9.
4) Caller receives ringback tone, but the call is not sended to PSTN.
I hope that clarifies the call flow
TIA
Andres
El mensaje fue editado por: Andres Pasten august 09
Haitham,
I´ve uploaded both full debugs:
- debug_incoming_090811_2.txt has the debug for the incoming call explained on my last post, which is working fine.
- debug_outgoing_090811_2.txt has the debug for the outgoing call explianed on my last post, which is not arriving to PSTN.
However there was less traffic on E1, some calls has appeared on the debugs.
Please let me know if you need something else.
TIA
Andres Pasten.
Andres
We sent setup :
Sending Complete
Standard = CCITT
-- haitham
Haitham,
Thanks for your support. I schedule test with telephony provider and it detected that rejects the call because of the ANI was in no isdn format. The E1 was sending just 4 digits, when I added the zone prefix + header, the call proceeds.
Once again thanks.
Bye,
Andres
