Call Drop Probl;em
Greetings,
Call Drop and we logged the below error message :
%C5510-4-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 1 dsp 15
VG Mode : AS535XM
IOS Version : 151-4.M10
DSP Firmware Version : 28.3.14
I know that this was related to a bug nut It is supposed to be fixed in the running IOS Version ;;; so any recommendation?
thanks,,,
Manish Gogna
Hi Karim,
Can you check if a router reload helps as per the following
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCua87806/?referring_site=bugquickviewredir
Also, an upgrade to latest IOS can be tried if the issue persists.
Manish
We already running the latest,so what we will gonna do it try to downgrade the IOS.
Restart did not solve the issue
