08-20-2012 08:18 AM - edited 03-16-2019 12:46 PM
Hello guys,
I've call dropping problems when dialing an external number from my VoIP network. Called number is a 0800 and it's answer by an IVR, with other called numbers everything works (hold, for example).
My issue is just with 0800 numbers!
ccCallDisconnect:
Cause Value=41, Call Entry(Disconnect Cause=0)
DEBUG VOIP CCAPI ALL gives:
SAE-CCS-DEFENSE-RTC-EXPE#
Aug 20 16:59:29.626: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
data_mode=0x10082
Aug 20 16:59:29.630: //857/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
Call Entry Is Not Found
Aug 20 16:59:29.634: //857/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
Aug 20 16:59:29.634: //-1/002128B70800/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=22.255.31.27
----- ccCallInfo IE subfields -----
cisco-ani=155238470
cisco-anitype=0
cisco-aniplan=1
cisco-anipi=1
cisco-anisi=1
dest=0820346020
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Aug 20 16:59:29.638: //-1/002128B70800/CCAPI/cc_api_call_setup_ind_common:
Interface=0x49F63A88, Call Info(
Calling Number=155238470,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Restricted),
Called Number=0820346020(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=857
Interface Type=0, Protocol=1
After Number Translation Checking:
Calling Number=155238470(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Restricted),
Aug 20 16:59:29.638: //857/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
Total Call Count=1
Aug 20 16:59:29.638: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 20 16:59:29.638: :cc_get_feature_vsa malloc success
Aug 20 16:59:29.638: cc_get_feature_vsa count is 1
Aug 20 16:59:29.638: :FEATURE_VSA attributes are: feature_name:0,feature_time:1206488552,feature_id:635
Aug 20 16:59:29.638: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Aug 20 16:59:29.638: call_init_entry calle is 47DCA560,callid is 857
Aug 20 16:59:29.638: //857/002128B70800/CCAPI/cc_insert_guid_pod_entry:
Incoming=TRUE, Call Id=857
Aug 20 16:59:29.638: //857/002128B70800/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=155238470(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Restricted),
Called Number=0820346020(TON=Unknown, NPI=Unknown))
Aug 20 16:59:29.638: //857/002128B70800/CCAPI/cc_incr_if_call_volume:
Remote IP Address=22.255.31.27, Hwidb=GigabitEthernet0/0
Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
Aug 20 16:59:29.638: //857/002128B70800/CCAPI/cc_process_call_setup_ind:
Event=0x50ACEFE8
Aug 20 16:59:29.638: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
Matching Parameters; Called Number=0820346020, Call Transfer Consult Id=
Aug 20 16:59:29.638: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Searching Node;
Aug 20 16:59:29.638: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
Aug 20 16:59:29.638: Comparing SSOpCode; 0x50 and 0x0
Aug 20 16:59:29.638: Comparing SSOpCode; 0x12 and 0x0
Try with the demoted called number 0820346020
No Matching Node
Aug 20 16:59:29.642: //-1/xxxxxxxxxxxx/CCAPI/ccAppInitializePID:
Application Process Name=_ManagedAppProcess_Default, Application Process Id=149, Application Handle=0x47DD1360
Aug 20 16:59:29.642: //857/002128B70800/CCAPI/ccCallSetContext:
Context=0x47DE74A0
Aug 20 16:59:29.642: //857/002128B70800/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 857 with tag 0 to app "_ManagedAppProcess_Default"
Aug 20 16:59:29.642: //-1/xxxxxxxxxxxx/CCAPI/ccAppInitialize:
Application Name=_ManagedAppProcess_Default, Application Process Id=149, Application Handle=0x4A934A28
Aug 20 16:59:29.642: //857/002128B70800/CCAPI/ccCallProceeding:
Aug 20 16:59:29.646: //857/002128B70800/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=1, Params=0x47DE9B00, Progress Indication=NULL(0)
Outgoing Dial-peer(Tag=1, Trunk Group List=0x50945710)
Aug 20 16:59:29.646: //857/002128B70800/CCAPI/cc_fill_tg_params:
Not a cic call
Params(Target Trkgrp Route Label=PSTN-IN, tg_label_flag=TRUE)
Trunk Group Select Interface Success;
Interface=0x50B13190, Selected Interface=1, Selected DSL=0
Aug 20 16:59:29.646: //857/002128B70800/CCAPI/ccCheckClipClir:
In: Calling Number=155238470(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Restricted)
Calling Party Number Is User Provided
Out: Calling Number=155238470(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Restricted)
Destination Pattern=0T, Called Number=0820346020, Digit Strip=TRUE
Redirect Number=, Display Info=
Account Number=22.255.31.27, Final Destination Flag=TRUE,
Guid=002128B7-F350-2103-0800-6002160A0B89, Outgoing Dial-peer=1
Aug 20 16:59:29.646: //857/002128B70800/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=155238470
cisco-anitype=0
cisco-aniplan=1
cisco-anipi=1
cisco-anisi=1
dest=0820346020
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-lastrdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Aug 20 16:59:29.646: //857/002128B70800/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x50B13190, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=155238470,(Calling Name=)(TON=Unknown, NPI=ISDN, Screening=User, Passed, Presentation=Restricted),
Called Number=0820346020(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=PSTN-IN, tg_label_flag=2, Application Call Id=)
Aug 20 16:59:29.646: //858/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
Aug 20 16:59:29.646: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Aug 20 16:59:29.646: :cc_get_feature_vsa malloc success
Aug 20 16:59:29.646: cc_get_feature_vsa count is 2
Aug 20 16:59:29.646: :FEATURE_VSA attributes are: feature_name:0,feature_time:1206488328,feature_id:636
Aug 20 16:59:29.646: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
Aug 20 16:59:29.646: call_init_entry calle is 47DCBD10,callid is 858
Aug 20 16:59:29.646: //857/002128B70800/CCAPI/cc_peer_bind:
Bind=TRUE, Binder Call Id=857, Bindee Call Id=858
Aug 20 16:59:29.646: //858/002128B70800/CCAPI/cc_insert_guid_pod_entry:
Incoming=FALSE, Call Id=858
Aug 20 16:59:29.646: //858/002128B70800/CCAPI/cc_set_voice_port_value:
CC_IF_TELEPHONY: Echo=0, Playout=0
Aug 20 16:59:29.650: //858/002128B70800/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Aug 20 16:59:29.650: //857/002128B70800/CCAPI/ccCallSetupRequest:
Trunk Group Call Setting;
Call Entry(Retry Count=0, Voice Class Cause Code=0)
Aug 20 16:59:29.650: //857/002128B70800/CCAPI/ccCallSetupRequest:exit@2521
Aug 20 16:59:29.650: //858/002128B70800/CCAPI/ccCallSetContext:
Context=0x47DE9AB0
Aug 20 16:59:29.650: //857/002128B70800/CCAPI/ccSaveDialpeerTag:
Aug 20 16:59:29.650: //857/002128B70800/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=PSTN-IN, tg_label_flag=TRUE, Call Id=0x359
Aug 20 16:59:30.090: //858/002128B70800/CCAPI/cc_api_call_proceeding:
Interface=0x50B13190, Progress Indication=NULL(0)
Aug 20 16:59:30.090: //858/002128B70800/CCAPI/cc_api_call_proceeding:exit@7008
Aug 20 16:59:30.854: //858/002128B70800/CCAPI/cc_api_call_cut_progress:
Interface=0x50B13190, Progress Indication=DESTINATION IS NON ISDN(2), Signal Indication=INTERCEPT(2),
Cause Value=0
Call Entry(Responsed=TRUE)
Aug 20 16:59:30.854: //857/002128B70800/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Aug 20 16:59:30.854: //858/002128B70800/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
Aug 20 16:59:30.854: //857/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x51EAE788, callID1=0x359, callID2=0x35A, tag=0x0)
(confID=0x51EAE788, callID1=0x359, gcid=0-0-0-0, tag=0x0)
Aug 20 16:59:30.854: //858/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x51EAE788, callID2=0x35A, gcid=0-0-0-0, tag=0x0)
Aug 20 16:59:30.854: //857/002128B70800/CCAPI/ccConferenceCreate:
Conference Id=0x51EAE788, Call Id1=857, Call Id2=858, Tag=0x0
Aug 20 16:59:30.854: //857/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Aug 20 16:59:30.854: cc_api_get_xcode_stream : 4534
Aug 20 16:59:30.854: //857/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x106, Source Interface=0x49F63A88, Source Call Id=857,
Destination Call Id=858, Disposition=0x0, Tag=0x0
Aug 20 16:59:30.854: //858/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x106, Source Interface=0x50B13190, Source Call Id=858,
Destination Call Id=857, Disposition=0x0, Tag=0xFFFFFFFF
Aug 20 16:59:30.854: //857/002128B70800/CCAPI/cc_generic_bridge_done:
Call Entry(Conference Id=0x106, Destination Call Id=858)
Aug 20 16:59:30.854: //858/002128B70800/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x106, Destination Call Id=857)
Aug 20 16:59:30.854: //858/002128B70800/CCAPI/cc_api_caps_ind:
Destination Interface=0x49F63A88, Destination Call Id=857, Source Call Id=858,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
Aug 20 16:59:30.858: //857/002128B70800/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x106, Call Id1=857, Call Id2=858
Aug 20 16:59:32.902: //857/002128B70800/CCAPI/cc_api_caps_ind:
Destination Interface=0x50B13190, Destination Call Id=858, Source Call Id=857,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Aug 20 16:59:32.902: //857/002128B70800/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1173)
Aug 20 16:59:32.902: //858/002128B70800/CCAPI/cc_api_caps_ack:
Aug 20 16:59:32.902: //858/002128B70800/CCAPI/cc_api_voice_mode_event:
Call Id=858
Aug 20 16:59:32.906: //858/002128B70800/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x47DE9AB0)
Call Id=858
Aug 20 16:59:32.906: //857/002128B70800/CCAPI/cc_api_caps_ind:
Aug 20 16:59:32.906: //857/002128B70800/CCAPI/cc_api_caps_ack:
Aug 20 16:59:32.906: //858/002128B70800/CCAPI/cc_api_caps_ack:
Aug 20 16:59:32.910: //858/002128B70800/CCAPI/cc_api_voice_mode_event:
Call Id=858
Aug 20 16:59:46.726: //858/002128B70800/CCAPI/cc_api_call_connected:
Interface=0x50B13190, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Aug 20 16:59:46.726: //858/002128B70800/CCAPI/cc_api_call_connected:exit@5772
Aug 20 16:59:46.730: //857/002128B70800/CCAPI/ccCallConnect:
Progress Indication=INBAND(8), Data Bitmask=0x1
Aug 20 16:59:46.730: //858/002128B70800/CCAPI/cc_api_get_called_ccm_detected:
Call Entry(Connected=TRUE, Responsed=TRUE)
Aug 20 16:59:58.731: //857/002128B70800/CCAPI/cc_api_call_disconnected:
Cause Value=41, Interface=0x49F63A88, Call Id=857
Call Entry(Responsed=TRUE, Cause Value=41, Retry Count=0)
Aug 20 16:59:58.731: //857/002128B70800/CCAPI/ccConferenceDestroy:
Conference Id=0x106, Tag=0x0
Aug 20 16:59:58.731: //-1/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
CALL_ERROR_INFORMATIONAL; mute call detection failed with confID=0x106
Aug 20 16:59:58.731: //857/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Aug 20 16:59:58.731: //858/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=857, Disposition=0x0, Tag=0x0
Aug 20 16:59:58.731: //857/002128B70800/CCAPI/cc_generic_bridge_done:
Aug 20 16:59:58.731: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
Aug 20 16:59:58.731: //857/002128B70800/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=41)
Start Calling Accounting;
Call Entry(Incoming=TRUE)
Cause Value=41, Call Entry(Disconnect Cause=41)
Cause Value=41, Call Entry(Responsed=TRUE, Cause Value=41)
Aug 20 16:59:58.731: //857/002128B70800/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Aug 20 16:59:58.731: //858/002128B70800/CCAPI/ccCallDisconnect:
Cause Value=41, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Call Entry(Incoming=FALSE)
Aug 20 16:59:58.731: //858/002128B70800/CCAPI/cc_api_get_transfer_info:
Aug 20 16:59:58.739: //857/002128B70800/CCAPI/cc_api_get_transfer_info:
Aug 20 16:59:58.739: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
ExpectFactor=0xA
Aug 20 16:59:58.739: //857/002128B70800/CCAPI/cc_decr_if_call_volume:
Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
Aug 20 16:59:58.743: //857/002128B70800/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x49F63A88, Tag=0x0, Call Id=857,
Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Aug 20 16:59:58.743: //857/002128B70800/CCAPI/cc_delete_guid_pod_entry:
Incoming=TRUE
Aug 20 16:59:58.743: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 20 16:59:58.743: :cc_free_feature_vsa freeing 47E98DE0
Aug 20 16:59:58.743: vsacount in free is 1
Aug 20 16:59:58.743: //857/002128B70800/CCAPI/cc_delete_call_entry:
Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
Total Call Count=0
Deleting profileTable[0x51B703CC]
Aug 20 16:59:58.747: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
Aug 20 16:59:58.747: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
Aug 20 16:59:59.327: //858/002128B70800/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x50B13190, Tag=0x0, Call Id=858,
tg for this call is PSTN-IN success/fail is 0
Prefix Is Not Defined From Peer; Peer=1, Called Number=0820346020
Aug 20 16:59:59.327: //858/002128B70800/CCAPI/cc_delete_guid_pod_entry:
Incoming=FALSE
Aug 20 16:59:59.327: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 20 16:59:59.327: :cc_free_feature_vsa freeing 47E98D00
Aug 20 16:59:59.331: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Aug 20 16:59:59.331: vsacount in free is 0
Aug 20 16:59:59.331: //858/002128B70800/CCAPI/cc_delete_call_entry:
Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
Deleting profileTable[0x51B702DC]
Aug 20 16:59:59.331: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
Aug 20 16:59:59.331: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
SAE-CCS-DEFENSE-RTC-EXPE#undebu
SAE-CCS-DEFENSE-RTC-EXPE#undebug all
All possible debugging has been turned off
"Media Termination Point Required" and "Wait for Far End H.245 Terminal Capability Set" are checked in the Call Manager (if unchecked, problem still the same).
ADDITIONAL INFORMATION:
SAE-CCS-DEFENSE-RTC-EXPE#sh h323 gateway cause-codes
CAUSE CODE STATISTICS AT 8w6d
DISC CAUSE CODE FROM OTHER PEER FROM H323 PEER
1 unassigned number (1) 3 6
3 no route to destinatio 5 0
16 normal call clearing ( 66 194
19 no user answer (19) 0 1
27 destination out of ord 0 9
38 network out of order ( 0 2
41 temporary failure (41) 79 1
102 recovery on timer expi 2 0
In my opinion my issues is related with mute and one time-out interval (maybe)...
Thanks in advance.
Alejandro
09-06-2012 04:01 AM
First of all congratulation for the workaround Cesar.
What I don't understand is why you had this problem, if you are listening to an IVR there is RTP traffic on the receive direction so it doesn't make sense. I am with Brian, it sounds like a bug or something.
09-10-2012 05:00 AM
Hi everybody,
I finally figured out with TAC Support the real cause of the issue (not MTP on the CM nor ip rtcp report interval).
On the gateway apply:
# config t
(config)# gateway
(config-gateway)# no timer receive-rtcp 6
(config-gateway)# no timer receive-rtp 1200
(config-gateway)# no media-inactivity-criteria all
These commands are configure to check for the media inactivity[ if no RTP and RTCP packets are received by the gateway] and to tear down the hung up calls if in case and sends the disconnect to PRI [ PSTN] and release complete to PBX or CUCM.
Normally MTP should be unchecked (CM) to avoid duplicated RTP packets on the WAN.
Good luck!
Cesar
