cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Call ended with Cause Code -1577058283
Hello Community,
does anyone knows the meaning of disconnect cause Code  -1577058283 ?
I can see this one everytime in CDR when a user tries to make phone calls to an international SIP trunk.
I could not find this cause code anywhere on Cisco.com.
1 RESPOSTA 1
Jaime Valencia
Might be this bug:
CUCM showing negative values in the "destCause_value" for 6XX termination codes
CSCvo66393
java
if this helps, please rate
