Call Failed with SIP 404 Not Found after SIP Refer message via SIP trunk
mid230
 Running a Cisco CUCM with multiple partitions along with a SIP trunk connected to another SIP based PBX used as an IVR. I'm able to place calls from any registered softphone or IP Communicator phone through the SIP Trunk and have IVR answer the call. IVR is also able to originate it's own call to one of the Softphones or IP Communicator phones without a problem.
When IVR attempts to perform a transfer via (REFER) from a softphone to another IP Communicator phone or vice versa we are getting a 404 User Not Found response. Any direction\help would be appreciated. I have this working on CUCM 8.6 but without TLS if that matters at all
26709521.003 |10:32:18.226 |AppInfo |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 10.50.130.196 on port 49498 index 21968 with 684 bytes:
[564133,NET]
REFER sip:8618@10.11.80.182:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 10.50.130.196;branch=z9hG4bKaZ2pc5my1gy0K
Max-Forwards: 70
To: <sip:8618@10.11.80.182>;tag=204361~c84093ec-dc7a-4720-9922-e2eab9ff0a2b-56104686
Call-ID: a6e5c200-84a1ce7d-10ef8-b6500b0a@10.11.80.182
CSeq: 100312704 REFER
Contact: <sip:3250@10.50.130.196:5061;transport=tls>
User-Agent: FreeSWITCH-mod_sofia/1.4.12~64bit
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, REFER, NOTIFY, PUBLISH, SUBSCRIBE
Supported: timer, path, replaces
Refer-To: <sip:8648@10.11.80.182>
Referred-By: <sip:10.50.130.196>
Content-Length: 0
At first the transfer is accepted and IVR recieves 3 messages (Accepted,Notify, Update)
26709554.001 |10:32:18.229 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.130.196 on port 49498 index 21968
[564134,NET]
SIP/2.0 202 Accepted
Date: Fri, 09 Dec 2016 15:32:18 GMT
Server: Cisco-CUCM10.5
Contact: <sip:8618@10.11.80.182:5061;transport=tls>
Content-Length: 0
26709573.001 |10:32:18.230 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.130.196 on port 5061 index 21961
[564135,NET]
NOTIFY sip:3250@10.50.130.196:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 10.11.80.182:5061;branch=z9hG4bK113fa32f0a8d1
From: <sip:8618@10.11.80.182>;tag=204361~c84093ec-dc7a-4720-9922-e2eab9ff0a2b-56104686
To: <sip:3250@10.50.130.196>;tag=SUKFv17pBc2yF
CSeq: 102 NOTIFY
Max-Forwards: 70
User-Agent: Cisco-CUCM10.5
Event: refer
Subscription-State: active;expires=60
P-Asserted-Identity: <sip:8618@10.11.80.182>
Content-Type: message/sipfrag;version=2.0
Content-Length: 20
SIP/2.0 100 Trying
26709603.001 |10:32:18.233 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.130.196 on port 5061 index 21961
[564136,NET]
UPDATE sip:3250@10.50.130.196:5061;transport=tls SIP/2.0
Via: SIP/2.0/TLS 10.11.80.182:5061;branch=z9hG4bK113fb1a344a5d
Max-Forwards: 70
Supported: timer,resource-priority,replaces
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 103 UPDATE
Call-Info: <urn:x-cisco-remotecc:callinfo>; security= Unknown; gci= 3-16761; isVoip
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=VIDEO_UNSPECIFIED
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-Expires: 1800;refresher=uac
Min-SE: 1800
Remote-Party-ID: <sip:8618@10.11.80.182>;party=calling;screen=yes;privacy=off
Content-Length: 0
After a short period another Notify is sent to IVR
26709630.001 |10:32:18.239 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.50.130.196 on port 5061 index 21961
[564137,NET]
Via: SIP/2.0/TLS 10.11.80.182:5061;branch=z9hG4bK113fc440e151b
CSeq: 104 NOTIFY
Max-Forwards: 70
Event: refer
Subscription-State: terminated
Content-Length: 23
SIP/2.0 404 Not Found
I think that for this the redirecting CSS on the SIP trunk in CM would be involved. Have you set this and does it see the needed partition(s) with the referenced information that the refer reference?
Response Signature
Could see that the CUCM digit analysis failing for the transferred number 8648.
26709601.008 |10:32:18.233 |AppInfo |Digit analysis: match(pi="1",fqcn="8618", cn="8618", plv="5", pss="", TodFilteredPss="", dd="8648",dac="0")
26709601.009 |10:32:18.233 |AppInfo |Digit analysis: potentialMatches=NoPotentialMatchesExist
So as suggested by Roger Kallberg, please find the CSS which contains the partition of extension 8648 and configure that CSS as the rerouting CSS in the SIP trunk
Rajan
Please rate all useful posts by clicking the star below and mark solutions as accepted wherever applicable
