Call fails after approximately 10 minutes with SIP/2.0 488 Not Acceptable Media
Humongous
Beginner
Beginner
It has happened two times with the same external number.  Any ideas - I am attaching logs and a trace file - let me know what else you need me to send - TIA!
013/10/28 13:32:34.381|SIPT|0|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|57315|2,100,220,1.774792^192.168.99.6^*|14463089|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|INVITE
2013/10/28 13:32:34.381|SIPT|0|UDP|OUT|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|5060|2,100,220,1.774792^192.168.99.6^*|14463090|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|100 Trying
2013/10/28 13:32:34.384|CC|SETUP|49652881|49652882|+191XXXXX222|3706|3706
2013/10/28 13:32:34.393|SIPT|49652881|UDP|OUT|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|5060|2,100,220,1.774792^192.168.99.6^*|14463091|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|180 Ringing
2013/10/28 13:32:36.577|SIPT|49652881|UDP|OUT|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|5060|1,100,50,1.61293731^192.168.46.10^HHH-BUF-MTP|14463094|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|200 OK
2013/10/28 13:32:36.595|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|57315|2,100,220,1.774793^192.168.99.6^*|14463095|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|ACK
2013/10/28 13:42:38.332|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774841^192.168.99.6^*|14463664|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|INVITE
2013/10/28 13:42:38.333|SIPT|49652881|UDP|OUT|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|5060|2,100,220,1.774841^192.168.99.6^*|14463665|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|100 Trying
2013/10/28 13:42:38.368|SIPT|49652881|UDP|OUT|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|5060|2,100,220,1.774841^192.168.99.6^*|14463666|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|488 Not Acceptable Media
2013/10/28 13:42:38.382|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774842^192.168.99.6^*|14463667|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|ACK
2013/10/28 13:42:38.418|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774843^192.168.99.6^*|14463668|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:42:38.915|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774844^192.168.99.6^*|14463671|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:42:39.914|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774846^192.168.99.6^*|14463676|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:42:41.915|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774847^192.168.99.6^*|14463679|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:42:45.915|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774848^192.168.99.6^*|14463680|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:42:49.915|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774849^192.168.99.6^*|14463681|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:42:53.914|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774851^192.168.99.6^*|14463690|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:42:57.914|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774852^192.168.99.6^*|14463695|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:43:01.914|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774855^192.168.99.6^*|14463707|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:43:05.914|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774856^192.168.99.6^*|14463710|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
2013/10/28 13:43:09.914|SIPT|49652881|UDP|IN|172.30.42.12|5060|HHH-BUF-CUBE|192.168.99.6|56256|2,100,220,1.774857^192.168.99.6^*|14463711|E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6|BYE
INVITE sip:71XXXX3706@172.30.42.12:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.99.6:5060;branch=z9hG4bKBE67190B
From: "CLIENT" <sip:91XXXXX222@10.250.0.6>;tag=5C565B10-262E
To: <sip:71XXXX3706@172.30.42.12>
Date: Mon, 28 Oct 2013 17:40:42 GMT
Call-ID: E6CBDB63-3F2E11E3-9A18BBB6-440D8BD3@192.168.99.6
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3872039699-1059983843-2584918966-1141738451
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1382982042
Contact: <sip:91XXXXX222@192.168.99.6:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 46
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 1446 7588 IN IP4 192.168.99.6
s=SIP Call
c=IN IP4 192.168.99.6
t=0 0
m=audio 22708 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
SIP/2.0 100 Trying
Date: Mon, 28 Oct 2013 17:32:34 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
SIP/2.0 180 Ringing
To: <sip:71XXXX3706@172.30.42.12>;tag=6359500~6d755948-9d75-4e9b-bf71-b6b4faa4840e-49652881
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "SAMUEL" <sip:3706@172.30.42.12>
Remote-Party-ID: "SAMUEL" <sip:3706@172.30.42.12>;party=called;screen=yes;privacy=off
Contact: <sip:71XXXX3706@172.30.42.12:5060>
Content-Length: 0
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Session-Expires: 50000;refresher=uas
Require: timer
Content-Length: 213
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 172.30.42.12
s=SIP Call
c=IN IP4 192.168.46.10
t=0 0
m=audio 31188 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
ACK sip:71XXXX3706@172.30.42.12:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.99.6:5060;branch=z9hG4bKBE68183A
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Via: SIP/2.0/UDP 192.168.99.6:5060;branch=z9hG4bKBE83244C
Date: Mon, 28 Oct 2013 17:50:46 GMT
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1382982646
Expires: 180
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 1446 7589 IN IP4 192.168.99.6
s=SIP Call
t=0 0
m=audio 22708 RTP/AVP 18
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:20
a=silenceSupp:off - - - -
SIP/2.0 100 Trying
Date: Mon, 28 Oct 2013 17:42:38 GMT
CSeq: 102 INVITE
Content-Length: 0
CSeq: 102 INVITE
Content-Length: 0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
BYE sip:71XXXX3706@172.30.42.12:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.99.6:5060;branch=z9hG4bKBE841253
Max-Forwards: 70
CSeq: 103 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=30087,OS=4813920,PR=30085,OR=4813600,PL=0,JI=0,LA=0,DU=601
Content-Length: 0
Max-Forwards: 70
CSeq: 103 BYE
Content-Length: 0
Max-Forwards: 70
Timestamp: 1382982647
CSeq: 103 BYE
Content-Length: 0
Max-Forwards: 70
Timestamp: 1382982649
CSeq: 103 BYE
Content-Length: 0
Max-Forwards: 70
Timestamp: 1382982653
CSeq: 103 BYE
Content-Length: 0
Ayodeji Okanlawon
Gary,
From the logs, Here is what I observed
Your gateway is sending a RE-INVITE to cucm during the call with a different media capabilites.The original call was established using G711ulaw. Then in the middle of the call, the CUBE sends  re-INVITE with only G729 advertised
To: <71XXXX3706>;tag=6359500~6d755948-9d75-4e9b-bf71-b6b4faa4840e-49652881
This is a little odd and unless we see the full logs that contain the other part of the call leg we wont know why your gateway is sending a re-INVITE with different media to the establised call.
So please send the full debug ccsip mesages...as we need to see the other side of the call.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Thanks for your response - do you want debug ccsip message or debug ccsip all? Thanks!
debug ccsip messages only
FYI - waiting for another meeting to be setup w/ this number.  I will collect debugs and send when that happens - thanks!
