01-11-2021 09:18 AM
Hi all,
I have configured CUBE box-box redundancy recently. It is all good when the CUBE1 is active. However, calls fail for both incoming&outgoing when CUBE failovers. Both CUBEs has the same configuration except the IP addresses of the interfaces.
CUBE WAN VIP: 10.38.0.99 DMZ on the firewall --> mapped to 207.195.52.111, which is pointing to ITSP 208.68.17.52 (One SIP Trunk)
CUBE LAN VIP: 10.20.140.99
CUCM IP: 10.41.40.10, 10.41.40.20, 10.121.121.7
CUBE1:
voice service voip
ip address trusted list
ipv4 10.41.40.10 255.255.255.255
ipv4 10.41.40.20 255.255.255.255
ipv4 10.121.121.7 255.255.255.255
ipv4 208.68.17.52 255.255.255.255
ipv4 10.38.0.99 255.255.255.255
ipv4 207.195.52.111 255.255.255.255
ipv4 10.20.140.99 255.255.255.255
address-hiding
mode border-element license capacity 200
media anti-trombone
allow-connections sip to sip
redundancy-group 1
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
rel1xx disable
header-passing
error-passthru
referto-passing
asserted-id pai
asymmetric payload dtmf
early-offer forced
midcall-signaling passthru
privacy-policy passthru
g729 annexb-all
pass-thru content sdp
interface Port-channel1.105
description DMZ SIP inbound
encapsulation dot1Q 105
ip address 10.38.0.100 255.255.255.0
bfd interval 3000 min_rx 3000 multiplier 3
redundancy rii 2
redundancy group 1 ip 10.38.0.99 exclusive
interface Port-channel1.140
description Uplink to 9504 Core
encapsulation dot1Q 140
ip address 10.20.140.100 255.255.255.0
redundancy rii 1
redundancy group 1 ip 10.20.140.99 exclusive
interface Port-channel1.3001
description CUBE-HA Heartbeat
encapsulation dot1Q 3001
ip address 172.28.140.100 255.255.255.248
redundancy
mode none
application redundancy
group 1
name CUBE-HA
priority 150 failover threshold 75
timers delay 30 reload 60
control Port-channel1.3001 protocol 1
data Port-channel1.3001
track 1 shutdown
track 2 shutdown
track 1 interface Port-channel1.140 line-protocol
track 2 interface Port-channel1.105 line-protocol
dial-peer voice 100 voip
description Incoming call from CUCM to CUBE
session protocol sipv2
incoming uri from 1
voice-class codec 1
voice-class sip bind control source-interface Port-channel1.140
voice-class sip bind media source-interface Port-channel1.140
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description Incoming Calls from ThinkTel to CUBE
call-block translation-profile incoming PSTN-CALLING-BLOCK
call-block disconnect-cause incoming call-reject
incoming called e164-pattern-map 2
voice-class codec 1
voice-class sip bind control source-interface Port-channel1.105
voice-class sip bind media source-interface Port-channel1.105
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description Incoming Call from CUBE to CUCM
session server-group 1
destination e164-pattern-map 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 201 voip
description Outgoing Call from CUBE to ThinkTel
session server-group 2
destination e164-pattern-map 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
CUB2:
redundancy
mode none
group 1
name CUBE-HA
priority 100 failover threshold 75
track 1 shutdown
track 2 shutdown
ip address 10.38.0.101 255.255.255.0
redundancy rii 2
ip address 10.20.140.101 255.255.255.0
redundancy rii 1
ip address 172.28.140.101 255.255.255.248
SIP trunk in CUCM is in full service and pointing to the CUBE LAN VIP.
Re-post this discussion since the old post is missing.
01-11-2021 09:20 AM
Debug for sip message for a success call via CUB1:
Calling party: 3068080271
Called party: 3063716658
Jan 5 16:17:06.249: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:3063716658@10.20.140.99:5060 SIP/2.0
Via: SIP/2.0/UDP 10.41.40.20:5060;branch=z9hG4bK1118f0f56950a49
From: "Eric x 0271" <sip:3068080271@10.41.40.20>;tag=119999886~db427c11-ebeb-49d8-a5ff-34bf61e982ae-40952101
To: <sip:3063716658@10.20.140.99>
Date: Tue, 05 Jan 2021 22:17:06 GMT
Call-ID: bd536280-ff41e562-ffb357-1428290a@10.41.40.20
Supported: timer,resource-priority,replaces
Min-SE: 60000
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 90
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.41.40.20:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Session-ID: 65b1e6f000105000a0006c410e5faac2;remote=00000000000000000000000000000000
Cisco-Guid: 3176358528-0000065536-0000083199-0338176266
Session-Expires: 60000
P-Asserted-Identity: "Eric x 0271" <sip:3068080271@10.41.40.20>
Privacy: none
Remote-Party-ID: "Eric x 0271" <sip:3068080271@10.41.40.20>;party=calling;screen=yes;privacy=off
Contact: <sip:3068080271@10.41.40.20:5060>;+u.sip!devicename.ccm.cisco.com="SEP6C410E5FAAC2"
Max-Forwards: 13
Content-Type: application/sdp
Content-Length: 203
v=0
o=CiscoSystemsCCM-SIP 119999886 1 IN IP4 10.41.40.20
s=SIP Call
c=IN IP4 10.41.40.20
t=0 0
m=audio 25470 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Jan 5 16:17:06.254: //673756/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.12.3
Session-ID: 00000000000000000000000000000000;remote=65b1e6f000105000a0006c410e5faac2
Content-Length: 0
Jan 5 16:17:06.258: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3063716658@208.68.17.52 SIP/2.0
Via: SIP/2.0/UDP 10.38.0.99:5060;branch=z9hG4bK285D7
From: "Eric x 0271" <sip:3068080271@10.38.0.99>;tag=108B44A7-17ED
To: <sip:3063716658@208.68.17.52>
Call-ID: 9448AC5A-4EDA11EB-8822B35C-F7DA4C82@10.38.0.99
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 60000
User-Agent: Cisco-SIPGateway/IOS-16.12.3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1609885026
Contact: <sip:3068080271@10.38.0.99:5060>
Expires: 180
Max-Forwards: 12
P-Asserted-Identity: "Eric x 0271" <sip:3068080271@10.38.0.99>
Content-Disposition: session;handling=required
Content-Length: 201
v=0
s=SIP Call
c=IN IP4 10.38.0.99
t=0 0
m=audio 8050 RTP/AVP 0 101
a=fmtp:101 0-15
Jan 5 16:17:06.312: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Giving a try
Via: SIP/2.0/UDP 10.38.0.99:5060;received=207.195.52.111;branch=z9hG4bK285D7
CSeq: 101 INVITE
Server: OpenSIPS (2.4.5 (x86_64/linux))
Content-Length: 0
Jan 5 16:17:06.313: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
WWW-Authenticate: Digest realm="edm.trk.tprm.ca",nonce="8b12a37e2858",stale=false,algorithm=MD5,qop="auth"
CSeq: 101 INVITE
To: <sip:3063716658@208.68.17.52>;tag=209.197.130.80+1+6d5802+e4ee9739
Server: DC-SIP/2.0
Organization: MetaSwitch
Supported: resource-priority, 100rel
Content-Length: 0
Jan 5 16:17:06.314: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3063716658@208.68.17.52 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: ;remote=
Content-Length: 0
Jan 5 16:17:06.315: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.38.0.99:5060;branch=z9hG4bK29178D
Min-SE: 60000
CSeq: 102 INVITE
Expires: 180
Authorization: Digest username="3068080270",realm="edm.trk.tprm.ca",uri="sip:3063716658@208.68.17.52",response="737e08de35cce511e1213f1d11029aa4",nonce="8b12a37e2858",cnonce="AD005A56",qop=auth,algorithm=MD5,nc=00000001
Max-Forwards: 12
Content-Length: 201
v=0
s=SIP Call
c=IN IP4 10.38.0.99
t=0 0
a=fmtp:101 0-15
Jan 5 16:17:06.369: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Received:
C4400_VG1_Colo#SIP/2.0 100 Giving a try
Via: SIP/2.0/UDP 10.38.0.99:5060;received=207.195.52.111;branch=z9hG4bK29178D
CSeq: 102 INVITE
Content-Length: 0
C4400_VG1_Colo#
Jan 5 16:17:09.931: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.20.140.99:5060 SIP/2.0
Via: SIP/2.0/UDP 10.41.40.20:5060;branch=z9hG4bK1118f1d6e625b2
To: <sip:10.20.140.99>
Date: Tue, 05 Jan 2021 22:17:09 GMT
Call-ID: bf1d2600-ff41e565-ffb365-1428290a@10.41.40.20
CSeq: 101 OPTIONS
Contact: <sip:10.41.40.20:5060>
Max-Forwards: 0
Content-Length: 0
Jan 5 16:17:09.933: //673758/967994898823/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.20.140.99>;tag=108B5302-1A10
CSeq: 101 OPTIONS
Accept: application/sdp
C4400_VG1_Colo#Supported: timer,resource-priority,replaces,sdp-anat
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 2831 4225 IN IP4 10.20.140.99
s=SIP Call
c=IN IP4 10.20.140.99
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
m=image 0 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:9600
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
C4400_VG1_Colo#
Jan 5 16:17:12.989: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
CSeq: 102 INVITE
To: <sip:3063716658@208.68.17.52>;tag=209.197.130.80+1+6dfa01+a7f528b4
Server: DC-SIP/2.0
Record-Route: <sip:208.68.17.142;r2=on;lr;ftag=108B44A7-17ED;nat=yes>
Record-Route: <sip:208.68.17.52;r2=on;lr;ftag=108B44A7-17ED;nat=yes>
Contact: <sip:3063716658@209.197.130.80:5060>
Content-Length: 240
v=0
o=- 3567264239 3567264239 IN IP4 209.197.130.112
s=-
c=IN IP4 208.68.17.60
t=0 0
a=rtpengine:345141277f9a
m=audio 57362 RTP/AVP 0 101
a=sendrecv
a=rtcp:57363
a=ptime:20
Jan 5 16:17:12.993: //673756/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:3063716658@10.20.140.99>;tag=108B5EF6-123F
CSeq: 101 INVITE
C4400_VG1_Colo#P-Asserted-Identity: <sip:3063716658@10.20.140.99>
Contact: <sip:3063716658@10.20.140.99:5060>
Supported: sdp-anat
Session-ID: 6fc2cc18b48952b18eaa6475b42da298;remote=65b1e6f000105000a0006c410e5faac2
Content-Length: 238
v=0
s=-
t=0 0
m=audio 8048 RTP/AVP 0 101
a=sendrecv
a=rtcp:8049
a=ptime:20
C4400_VG1_Colo#
Jan 5 16:17:17.071: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.121.121.7:5060;branch=z9hG4bK4fbc452c176324
Date: Tue, 05 Jan 2021 22:17:17 GMT
Call-ID: c3e1da00-ff41e56d-4b5768-779790a@10.121.121.7
CSeq: 101 OPTIONS
Contact: <sip:10.121.121.7:5060>
Max-Forwards: 0
Content-Length: 0
Jan 5 16:17:17.073: //673759/9ABB10808824/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.20.140.99>;tag=108B6EE6-1518
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 8904 1972 IN IP4 10.20.140.99
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
C4400_VG1_Colo#
Jan 5 16:17:19.099: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.41.40.10:5060;branch=z9hG4bKaee08f124e817d
Date: Tue, 05 Jan 2021 22:17:19 GMT
Call-ID: c5130700-ff41e56f-ad36d0-a28290a@10.41.40.10
CSeq: 101 OPTIONS
Contact: <sip:10.41.40.10:5060>
Max-Forwards: 0
Content-Length: 0
Jan 5 16:17:19.101: //673760/9BF05C738825/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.20.140.99>;tag=108B76D2-1F27
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 6153 1314 IN IP4 10.20.140.99
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
C4400_VG1_Colo#
Jan 5 16:17:21.116: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Server: DC-SIP/2.0
Allow-Events: message-summary, refer, dialog, line-seize, presence, call-info, as-feature-event
Allow: INVITE, ACK, CANCEL, BYE, REGISTER, OPTIONS, PRACK, UPDATE, SUBSCRIBE, NOTIFY, REFER, INFO, PUBLISH
Accept-Encoding: identity
Accept: application/sdp, application/simple-message-summary, message/sipfrag, application/x-simple-call-service-info, text/plain
Content-Length: 240
v=0
s=-
t=0 0
a=sendrecv
a=rtcp:57363
a=ptime:20
Jan 5 16:17:21.119: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3063716658@209.197.130.80:5060 SIP/2.0
Via: SIP/2.0/UDP 10.38.0.99:5060;branch=z9hG4bK2AD0F
Route: <sip:208.68.17.52;r2=on;lr;ftag=108B44A7-17ED;nat=yes>,<sip:208.68.17.142;r2=on;lr;ftag=108B44A7-17ED;nat=yes>
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jan 5 16:17:21.120: //673756/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 238
v=0
s=-
t=0 0
a=sendrecv
a=rtcp:8049
a=ptime:20
C4400_VG1_Colo#
Jan 5 16:17:21.129: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:3063716658@10.20.140.99:5060 SIP/2.0
Via: SIP/2.0/UDP 10.41.40.20:5060;branch=z9hG4bK1118f2c410216cd
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
C4400_VG1_Colo#
Jan 5 16:17:25.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.41.40.20:5060;branch=z9hG4bK1118f35693a7c89
Date: Tue, 05 Jan 2021 22:17:25 GMT
Call-ID: c8a68e00-ff41e575-ffb37b-1428290a@10.41.40.20
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Jan 5 16:17:25.074: //673761/9F7FC4808826/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.20.140.99>;tag=108B8E27-1C99
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 4243 6163 IN IP4 10.20.140.99
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
C4400_VG1_Colo#
Jan 5 16:17:32.953: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.121.121.7:5060;branch=z9hG4bK4fbc5522ea447c
Date: Tue, 05 Jan 2021 22:17:32 GMT
Call-ID: ccd2ab80-ff41e57c-4b5778-779790a@10.121.121.7
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Jan 5 16:17:32.955: //673762/A432757E8827/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.20.140.99>;tag=108BACF0-1555
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 3148 5298 IN IP4 10.20.140.99
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
Jan 5 16:17:34.627: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.41.40.10:5060;branch=z9hG4bKaee09e5316848f
Date: Tue, 05 Jan 2021 22:17:34 GMT
Call-ID: ce03d880-ff41e57e-ad36df-a28290a@10.41.40.10
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Jan 5 16:17:34.629: //673763/A531BDE08828/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.20.140.99>;tag=108BB37A-166A
CSeq: 101 OPTIONS
Content-Length: 373
v=0
o=CiscoSystemsSIP-GW-UserAgent 7633 9942 IN IP4 10.20.140.99
s=SIP Call
t=0 0
m=image 0 udptl t38
a=T38FaxVersion:0
C4400_VG1_Colo#
Jan 5 16:17:40.280: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:3068080271@207.195.52.111:52765 SIP/2.0
Record-Route: <sip:208.68.17.52;r2=on;lr;ftag=209.197.130.80+1+6dfa01+a7f528b4>
Record-Route: <sip:208.68.17.142;r2=on;lr;ftag=209.197.130.80+1+6dfa01+a7f528b4>
Via: SIP/2.0/UDP 208.68.17.52:5060;branch=z9hG4bK9f9b.a1f33d36.0
Via: SIP/2.0/UDP 209.197.130.80:5060;received=209.197.130.80;rport=5060;branch=z9hG4bK-180d7c70b257419b950d864b8468bd201-209.197.130.80-1
Max-Forwards: 69
From: <sip:3063716658@208.68.17.52>;tag=209.197.130.80+1+6dfa01+a7f528b4
To: "Eric x 0271" <sip:3068080271@10.38.0.99>;tag=108B44A7-17ED
CSeq: 568409216 BYE
Content-Length: 0
Jan 5 16:17:40.282: //673756/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3068080271@10.41.40.20:5060 SIP/2.0
Via: SIP/2.0/UDP 10.20.140.99:5060;branch=z9hG4bK2BE06
From: <sip:3063716658@10.20.140.99>;tag=108B5EF6-123F
To: "Eric x 0271" <sip:3068080271@10.41.40.20>;tag=119999886~db427c11-ebeb-49d8-a5ff-34bf61e982ae-40952101
Date: Tue, 05 Jan 2021 22:17:21 GMT
Timestamp: 1609885060
CSeq: 101 BYE
Reason: Q.850;cause=16
Max-Forwards: 69
Content-Length: 0
Jan 5 16:17:40.283: //673757/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 208.68.17.52:5060;branch=z9hG4bK9f9b.a1f33d36.0,SIP/2.0/UDP 209.197.130.80:5060;received=209.197.130.80;rport=5060;branch=z9hG4bK-180d7c70b257419b950d864b8468bd201-209.197.130.80-1
Date: Tue, 05 Jan 2021 22:17:40 GMT
CSeq: 568409216 BYE
Session-ID: 65b1e6f000105000a0006c410e5faac2;remote=6fc2cc18b48952b18eaa6475b42da298
Content-Length: 0
C4400_VG1_Colo#
Jan 5 16:17:40.291: //673756/BD5362800001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Server: Cisco-CUCM11.5
CSeq: 101 BYE
Content-Length: 0
Debug for sip message for a failed call on CUBE2 with the same calling party and called party number.
C4400_VG2_Colo#
Jan 7 10:56:30.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.121.121.7:5060;branch=z9hG4bK52af7577ab6451
From: "Eric x 0271" <sip:3068080271@10.121.121.7>;tag=44948356~db427c11-ebeb-49d8-a5ff-34bf61e982ae-64097500
Date: Thu, 07 Jan 2021 16:56:30 GMT
Call-ID: 489a3880-ff713d3e-4e1e81-779790a@10.121.121.7
Min-SE: 60000
CSeq: 101 INVITE
Expires: 90
Call-Info: <sip:10.121.121.7:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Session-ID: 0baadb8200105000a0006c410e5faac2;remote=00000000000000000000000000000000
Cisco-Guid: 1218066560-0000065536-0000024083-0125401354
P-Asserted-Identity: "Eric x 0271" <sip:3068080271@10.121.121.7>
Privacy: none
Remote-Party-ID: "Eric x 0271" <sip:3068080271@10.121.121.7>;party=calling;screen=yes;privacy=off
Contact: <sip:3068080271@10.121.121.7:5060>;+u.sip!devicename.ccm.cisco.com="SEP6C410E5FAAC2"
Max-Forwards: 13
Content-Length: 203
v=0
o=CiscoSystemsCCM-SIP 44948356 1 IN IP4 10.121.121.7
s=SIP Call
t=0 0
m=audio 31346 RTP/AVP 0 101
a=fmtp:101 0-15
Jan 7 10:56:30.473: //702341/489A38800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=0baadb8200105000a0006c410e5faac2
Content-Length: 0
Jan 7 10:56:30.477: //702342/489A38800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3063716658@208.68.17.52:5060 SIP/2.0
Via: SIP/2.0/UDP 10.38.0.99:5060;branch=z9hG4bK1601
From: "Eric x 0271" <sip:3068080271@10.38.0.99>;tag=D8637E50-25E8
Call-ID: 1FB0EC5E-504011EB-A9AEE54E-6B15A641@10.38.0.99
Min-SE: 60000
CSeq: 101 INVITE
Timestamp: 1610038590
Expires: 180
Max-Forwards: 12
C4400_VG2_Colo#Content-Length: 201
v=0
s=SIP Call
c=IN IP4 10.38.0.99
t=0 0
m=audio 8006 RTP/AVP 0 101
a=fmtp:101 0-15
Jan 7 10:56:30.978: //702342/489A38800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 60000
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 12
v=0
s=SIP Call
c=IN IP4 10.38.0.99
t=0 0
a=fmtp:101 0-15
Jan 7 10:56:31.978: //702342/489A38800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 07 Jan 2021 16:56:31 GMT
Min-SE: 60000
CSeq: 101 INVITE
Timestamp: 1610038591
Expires: 180
Max-Forwards: 12
v=0
s=SIP Call
c=IN IP4 10.38.0.99
t=0 0
a=fmtp:101 0-15
C4400_VG2_Colo#
Jan 7 10:56:33.979: //702341/489A38800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 408 Request Timeout
To: <sip:3063716658@10.20.140.99>;tag=D8638BFE-1990
CSeq: 101 INVITE
Reason: Q.850;cause=102
Content-Length: 0
C4400_VG2_Colo#
Jan 7 10:56:34.002: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
C4400_VG2_Colo#
Jan 7 10:56:40.586: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.41.40.10:5060;branch=z9hG4bKb15ec04b579268
Date: Thu, 07 Jan 2021 16:56:40 GMT
Call-ID: 4e901980-ff713d48-afadf7-a28290a@10.41.40.10
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Jan 7 10:56:40.588: //702343/25B7BD62A9AF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:10.20.140.99>;tag=D863A5CE-22FC
CSeq: 101 OPTIONS
CUBE2 sent invite message three times but not any response in return from ISTP
01-11-2021 09:28 AM
There is no ip routing issue on the CUBE2 to ISTP
C4400_VG2_Colo#ping 208.68.17.52 source 10.38.0.101
Sending 5, 100-byte ICMP Echos to 208.68.17.52, timeout is 2 seconds:
Packet sent with a source address of 10.38.0.101
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/56/57 ms
C4400_VG2_Colo#show redundancy application group
Group ID Group Name State
1 CUBE-HA ACTIVE
01-11-2021 09:47 AM - edited 01-11-2021 09:48 AM
No that easy to digest the debug output on a mobile phone, but one difference I see is that there is no authentication happening on SBC2. Not sure if this is the problem or not, but something that sticks out anyway.
01-11-2021 09:40 AM
It would be so much easier to read your debug output if you attach it in individual files per SBC instead of putting the text directly in the post.
01-11-2021 11:06 AM
The authentication under sip-ua is the same.
CUBE1:
sip-ua
authentication username 3068080270 password 6 cBHFeFMFhRV`WgULZbSYFUZHabb]fZQE]FbCgPT realm edm.trk.tprm.ca
disable-early-media 180
retry invite 2
retry response 3
retry register 4
retry options 4
CUBE2:
sip-ua
retry invite 2
retry response 3
retry register 4
retry options 4
The log files are attached.
01-11-2021 11:53 AM
SBC2 never get any traffic from your ISP, neither answer on invite or sip option ping. You need to check with them if they actually receive the traffic from the cube and if so why they don’t respond to it.
01-11-2021 12:55 PM
Yep, there is no any response in return from ISTP. It is odd, actually, CUBE1 and CUBE2 are using the same WAN VIP (10.38.0.99 and mapped to a public IP 207.195.52.111 on the firewall).
01-11-2021 01:45 PM
Hi Roger,
The user has purchased 200 CUBE RED licenses. Do i need to apply " mode border-element license capacity 200" for both CUBEs?
01-11-2021 01:48 PM
I found this under Cisco license portal, could be the license issue.
01-11-2021 03:10 PM - edited 01-11-2021 03:11 PM
Hi there,
The ITSP is not responding when the call is on CUBE 2, so either the ITSP are not receiving your traffic or they are receiving it, but are somehow not responding to CUBE 2. Odd you might think as the VIP is mapped to the same public IP as you say.
Are we sure that CUBE 2 SIP trunk is authenticated with your ITSP? E.g. if you issue a "show sip-ua register status" on both CUBEs, are the outputs the same?
Would it also be possible to supply a copy of the configuration of the two CUBE's too?
01-11-2021 07:37 PM
Hi Scott,
You meant that the WAN VIP (10.38.0.99 in DMZ) cannot be mapped to the same public IP? We only have one sip trunk to the ITSP. In addition, there is nothing coming up when i issued the command "show sip-ua register status" on both CUBEs.
Also, it could be the issue for activating the CUBE license (CUBE-200-RED), no sure if it is correct that i only applied the command " mode border-element license capacity 200" on the CUBE1, and the command "mode border-element" under voice service voip on the CUBE2? As my point of view, the CUBE license should be transferred to the standby CUBE when CUBE failovers. However, i got "CUBE app is not enabled" when i run the command "show cube status" on the CUBE2.
The running configure for both CUBE are attached.
Thanks.
01-12-2021 12:38 AM
Hi there,
Both config files you have supplied are of cube1.
01-12-2021 07:10 AM
01-12-2021 07:27 AM - edited 01-12-2021 07:30 AM
Thank you Eric,
On CUBE2 would you be able to change your session target on dial-peer 201 to "session server-group 2" so that it matches the config on CUBE1 please and test again?
Scott
